ST STM32F103ZGT6 32位ARM Cortex-M3 MCU开发评估方案
2012年04月29日 09:15 发布者:1770309616
ST公司的STM32F103x4和STM32F103x6是基于ARM Cortex™-M3的32位RISC核的MCU,工作频率72MHz,集成了16或32KB闪存,USB,CAN,6个定时器,2个ADC和六个通信接口.电源电压2.0V-3.6V,有两种温度范围: –40到+85 ℃和–40 to到+105 ℃.主要用在马达驱动,工业应用,医疗和手持设备,PC和游戏外设,GPS平台,PLC,逆变器,打印机,扫描仪和HVAC等.本文介绍了STM32F103x4和STM32F103x6主要特性,方框图,以及STM3210E-EVAL评估板主要特性,方框图,电路图和PCB元件布局图.STM32F103x4和STM32F103x6: Low-density performance line, ARM-based 32-bit MCU with 16 or 32 KB Flash, USB, CAN, 6 timers, 2 ADCs, 6 communication interfaces
The STM32F103x4 and STM32F103x6 performance line family incorporates the highperformance ARM Cortex™-M3 32-bit RISC core operating at a 72 MHz frequency, highspeed embedded memories (Flash memory up to 32 Kbytes and SRAM up to 6 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses. All devices offer two 12-bit ADCs, three general purpose 16-bit timers plus one PWM timer, as well as standard and advanced communication interfaces: up to two I2Cs and SPIs, three USARTs, an USB and a CAN.
The STM32F103xx low-density performance line family operates from a 2.0 to 3.6 V power supply. It is available in both the –40 to +85 ℃temperature range and the –40 to +105 ℃ extended temperature range. A comprehensive set of power-saving mode allows the design of low-power applications.
The STM32F103xx low-density performance line family includes devices in four different package types: from 36 pins to 64 pins. Depending on the device chosen, different sets of peripherals are included, the description below gives an overview of the complete range of peripherals proposed in this family.
These features make the STM32F103xx low-density performance line microcontroller family suitable for a wide range of applications such as motor drives, application control, medical and handheld equipment, PC and gaming peripherals, GPS platforms, industrial applications, PLCs, inverters, printers, scanners, alarm systems, video intercoms, and HVACs.
STM32F103x4和STM32F103x6主要特性:
■ ARM 32-bit Cortex™-M3 CPU Core
– 72 MHz maximum frequency, 1.25 DMIPS/MHz (Dhrystone 2.1) performance at 0 wait state memory access
– Single-cycle multiplication and hardware division
■ Memories
– 16 or 32 Kbytes of Flash memory
– 6 or 10 Kbytes of SRAM
■ Clock, reset and supply management
– 2.0 to 3.6 V application supply and I/Os
– POR, PDR, and programmable voltage detector (PVD)
4-to-16 MHz crystal oscillator
– Internal 8 MHz factory-trimmed RC
– Internal 40 kHz RC
– PLL for CPU clock
– 32 kHz oscillator for RTC with calibration
■ Low power
– Sleep, Stop and Standby modes
– VBAT supply for RTC and backup registers
■ 2 x 12-bit, 1 μs A/D converters (up to 16 channels)
–Conversion range: 0 to 3.6 V
–Dual-sample and hold capability
–Temperature sensor
■ DMA
– 7-channel DMA controller
– Peripherals supported: timers, ADC, SPIs, I2Cs and USARTs
■ Up to 51 fast I/O ports
– 26/37/51 I/Os, all mappable on 16 external interrupt vectors and almost all 5 V-tolerant
■ Debug mode
– Serial wire debug (SWD) & JTAG interfaces
■ 6 timers
– Two 16-bit timers, each with up to 4 IC/OC/PWM or pulse counter and quadrature (incremental) encoder input
– 16-bit, motor control PWM timer with deadtime generation and emergency stop
– 2 watchdog timers (Independent and Window)
– SysTick timer 24-bit downcounter
■ 6 communication interfaces
– 21 x I2C interface (SMBus/PMBus)
– 2 × USARTs (ISO 7816 interface, LIN, IrDA capability, modem control)
– 1 × SPI (18 Mbit/s)
– CAN interface (2.0B Active)
– USB 2.0 full-speed interface
■ CRC calculation unit, 96-bit unique ID
■ Packages are ECOPACK®
图1.STM32F103xx方框图
STM3210E-EVAL评估板
The STM3210E-EVAL evaluation board is designed as a complete development platform for STMicroelectronic’s ARM Cortex-M3 core-based STM32F103ZGT6 microcontroller with full speed USB2.0, CAN2.0A/B compliant interface, two I2S channels, two I2C channels, five USART channels with smartcard support, three SPI channels, two DAC channels, FSMC interface, SDIO, internal 96 KB SRAM and 1 MB Flash, JTAG and SWD debug support.
The STM3210E-EVAL products delivered with the MB672 board versions D-03 or older are based on the STM32F103ZET6 instead of the STM32F103ZGT6 and include 64 KB internal SRAM and 512 KB Flash. The board number and version are on a label on the bottom side of the board.
The full range of hardware features on the board helps you to evaluate all peripherals (USB, motor control, CAN, MicroSD Card, smartcard, USART, NOR Flash, NAND Flash, SRAM) and develop your own applications. Extension headers make it easy to connect a daughterboard or wrapping board for your specific application.
图2. STM3210E-EVAL评估板外形图
The STM3210E-EVAL evaluation board is designed around the STM32F103ZGT6 microcontroller in a 144-pin TQFP package.
STM3210E-EVAL评估板主要特性:
● Three 5 V power supply options: power jack, USB connector or daughterboard
● Boot from user Flash, system memory or SRAM
● I2S audio DAC, stereo audio jack
● 128 Mbyte MicroSD CardTM
● Both A and B type smartcard support
● 64 or 128 Mbit serial Flash, 512 Kx16 SRAM, 512 Mbit or 1 Gbit NAND Flash and 128Mbit NOR Flash
● I2C/SMBus compatible serial interface temperature sensor
● Two RS-232 channels with RTS/CTS handshake support on one channel
● IrDA transceiver
● USB2.0 full speed connection
● CAN2.0A/B compliant connection
● Inductor motor control connector
● JTAG and trace debug support
● 240x320 TFT color LCD
● Joystick with 4-direction control and selector
● Reset, wakeup, tamper and user buttons
● 4 color LEDs
● RTC with backup battery
图3.STM3210E-EVAL评估板硬件方框图
图4.STM3210E-EVAL评估板电路图:MCU连接
图5.STM3210E-EVAL评估板电路图:MCU
图6.STM3210E-EVAL评估板电路图:外设
图7.STM3210E-EVAL评估板电路图:RS-232和IrDA连接器
图87.STM3210E-EVAL评估板电路图:音频
图9.STM3210E-EVAL评估板电路图: LCD和控制杆连接器
图10.STM3210E-EVAL评估板电路图:SD卡和智能卡
图11.STM3210E-EVAL评估板电路图:马达控制
图12.STM3210E-EVAL评估板电路图:JTAG和跟踪连接器
图13.STM3210E-EVAL评估板电路图:电源
图14.STM3210E-EVAL评估板电路图:SRA和闪存
图15.STM3210E-EVAL评估板电路图:彩色LCD模块
图16.STM3210E-EVAL评估板元件布局图
详情请见:
75098和
75099
来源:网络
