Silicon-Based RF Front-Ends for Ultra Wideband Radios
2012年04月24日 15:15    发布者:看门狗
Series: Analog Circuits and Signal Processing
Safarian, Aminghasem, Heydari, Payam
2008, VIII, 100 p., Hardcover
ISBN: 978-1-4020-6721
About this book
Ultra-wideband (UWB) is a promising technology for high speed short distance communication, as well as low data-rate low power communication for object localization and sensor networks. The most important characteristic of UWB is the operation in power-limited regime while achieving high channel capacity. The main challenge lies in designing transceivers for wideband signals.
Distributed integrated circuits provide intrinsic wideband characteristics, which makes them potential candidate for use in UWB transceivers. Recent advances in high-speed IC design with continuous scaling of minimum feature sizes of silicon technologies have renewed the interest in distributed circuits using on-chip transmission lines.
Silicon-Based RF Front-Ends for UWB Radios comprehensively studies silicon-based distributed architectures in wideband circuits.
The book begins with an introduction of several transceiver architectures for UWB. The discussion then focuses on RF front-end of the UWB radio. First, the design and analysis of a performance-optimized CMOS distributed LNA is presented. This is followed by design of novel distributed RF front-ends for UWB IF-receivers (UWB-DRF). The book continues with the introduction of a novel distributed direct conversion RF front-end (DDC-RF). The DDC-RF power and area-efficiently combines the wideband distributed approach with IQ requirement of a direct conversion receiver. Furthermore, deploying merged LNA/mixer enables low-power design, while achieving superior linearity over the conventional distributed amplifiers. The baseband output signals are zero/ low-IF, hence the output transmission lines in conventional distributed circuits are omitted, resulting in less area of the DDC-RF.
To increase data rate and to achieve immunity to multi-path fading, UWB systems employs multi-antenna configuration at receiver/transmitter. Innovative wideband variable delay and gain stages are then introduced to receive and transmit in desired direction. Finally, experimental results of the fabricated prototypes are presented.
Silicon-Based RF Front-Ends for UWB Radios will be of interest to RF circuit designers and students.
Written for:
Analog and radio-frequency (RF) integrated circuit (IC) designers; circuit researchers and educators; education of graduate and undergraduate students
74682
该文章有附件资料,如需下载请访问 电脑版。
rinllow6 2012年04月26日
谢谢!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
daizhi1970 2012年08月03日
O(∩_∩)O谢谢
wyhbox 2012年10月06日
谢谢分享
wyhbox 2012年10月06日
谢谢
