IQ Calibration Techniques for CMOS Radio Transceivers
2012年04月24日 14:25 发布者:看门狗
IQ Calibration Techniques for CMOS Radio TransceiversSeries: Analog Circuits and Signal Processing
Chen, Sao-Jie, Hsieh, Yong-Hsiang
2006, XIX, 90 p., Hardcover
ISBN: 978-1-4020-5082-4
About this book
In the market of wireless communication, high data-rate transmission and high spectral efficiency have been the trend. The IEEE 802.11 a/g standards working at 5GHz/2.4GHz ISM bands can support data rate up to 54Mbits/s using OFDM modulation. The newly proposed 802.11n technology now uses 64-QAM to achieve higher spectral efficiency. The DVB and many other systems will also use QAM for its data transmission.
The cost of achieving this higher spectral efficiency using higher order QAM is that the transmitter and receiver requires a higher signal to noise ratio (SNR) with the same level of error rate performance (relative to a baseline BPSK, QPSK and other systems). One of the dominant vectors on SNR degradation is I/Q image rejection (I/Q gains and phases imbalance).
There are a lot of factors that degrade the matching of gains and phases between I/Q signals: the instinct layout mismatch, the random mismatch of the devices, the different temperatures over the I/Q signal paths. IQ Calibration Techniques For CMOS Radio Transceivers describes a fully-analog compensation technique without baseband circuitry to control the calibration process. This book will use an 802.11g transceiver design as an example to give a detailed description on the I/Q gains and phases imbalance auto-calibration mechanism.
Written for:
RF transceiver designers, RF IC designers, RF system designers, analog IC designers, and graduate level students in analog / RF degree
74674
rinllow6 2012年04月25日
谢谢!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
wyhbox 2012年10月06日
谢谢分享
谢谢分享
jushilq 2015年11月22日
多谢分享!!
多谢分享!!
谢谢!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
