AKM AK4203立体声线路和视频放大器解决方案
2012年03月16日 20:04 发布者:1770309616
AKM 公司的AK4203是立体声无电容线路放大器和视频放大器,具有内置的电荷泵电路,采用单个3.3V电源,可得到2Vrms输出,并具有极好的线性度.音频放大器的THD+N为 -90dB, S/N为102dB,视频放大器的S/N为75dB(typ),放大器增益为+6dB.本文介绍了AK4203主要特性,方框图,典型连接图,评估板AKD4203-A功能和方框图,以及电路图和元件布局图.Stereo Cap-less LINE-Amp and Video-Amp
The AK4203 is an audio stereo cap-less line driver with 1-channel video driver. It eliminates the need for large DC-blocking capacitors with a built-in Charge-pump circuit. The AK4203 achieves 2Vrms outputs with excellent linearity 2Vrms output by single 3.3V power supply. The AK4203 is available in small 16-pin TSSOP, saving the system space and cost.
AK4203主要特性:
Audio Line-Amp
􀂆 Differential Input
􀂆 Stereo Cap-less Amplifier (No DC-blocking capacitors required)
􀂆 Line-Out level: 2.0Vrms
􀂆 THD+N: -90dB
􀂆 S/N: 102dB
􀂆 Output gain: 6dB
􀂆 Low-pass Filter: fc= 130kHz
􀂆 Pop Noise Free Ground-referenced Output Video Amp
􀂆 1ch Stereo Cap-less Amplifier (No DC-blocking capacitors required)
􀂆 Integrated Video Amplifier (+6dB)
􀂆 Input Level: 1.5Vpp (max)
􀂆 SN: 75dB(typ), Bandwidth: 100kHz ∼ 6MHz
􀂆 LPF: -0.5dB@ 6.75MHz (typ), -43dB@27MHz (typ)
􀂆 Video Mute Function
􀂆 Power Supply: 3.0V ~ 3.6V
􀂆 Ta: -20 ~ 85℃
􀂆 Package: 16TSSOP
图1.AK4203 方框图
图2.AK4203 典型连接框图
AK4203评估板AKD4203-A
The AKD4203-A is an evaluation board for a fast evaluation of the AK4203,
Evaluation requires audio/video analog analyzers/generators and a power supply.
评估板AKD4203-A功能:
• RCA jacks for analog audio input/output
• XLR jacks for analog audio input
• RCA jacks for video input/output
图3.评估板AKD4203-A方框图
图4.评估板AKD4203-A电路图(1)
图5.评估板AKD4203-A电路图(2)
图6.评估板AKD4203-A电路图(3)
图7.评估板AKD4203-A电路图(4)
图8.评估板AKD4203-A元件布局图
详情请见:
69746和
69755
