Renesas SH7216 32位MCU开发方案
2012年02月15日 12:56 发布者:1770309616
Renesas公司的 SH7216系列是32位SH-2A RISC CPU核的微控制器,最大工作频率200MHz,具有400 MIPS新能,集成了大容量高速闪存和RAM以及电源降压电路,PWM定时器,12位ADC,LAN控制器,USB和CAN外设。工作电压3.3V,主要用在工业设备包括PLC,AC伺服系统和通用逆变器等。本文介绍了SH7216主要特性及其开发板目标应用和主要特性,方框图,和PC连接图与详细电路图。The SH7216 Series with 32-bit SH-2A CPU core offers a maximum operating frequency of 200 MHz, representing a 1.25-fold improvement in performance over the 160 MHz of Renesas Electronics’s existing the SH7211. They also include large-capacity high-speed flash memory and RAM through the use of cutting-edge flash memory technology. Featuring an on-chip power supply step-down circuit, these microcontrollers are designed to achieve lower current dissipation by suppressing the increase in current dissipation associated with higher speed, and attain 3.3 V single-power-supply operation while at the high operating frequency of 200 MHz. In addition, the SH7216 Series incorporates a PWM timer, 12-bit AD converter, LAN controller, USB, and CAN as peripheral functions.
The SH7216 Series lineup consists of the SH7216 Group (with floating-point unit (FPU)) and the SH7214 Group (without FPU).
SH7216主要特性:
High-performance single-chip RISC with SH-2A core
400 MIPS 200 MHz
Built-in 32-bit multiplier
With floating-point unit (FPU): SH7216 Group
Without floating-point unit (FPU): SH7214 Group
Built-in large-capacity memory
ROM 1MB
RAM 128KB
Various peripheral functions
Powerful timers: MTU2 (16 bits x 6 ch), MTU2S (16 bits x 3 ch), Compare match timer (CMT) x 2 channels
A/D converters (12-bit resolution): 8 ch (4 ch x 2 units)
Ether MAC: 1 ch
USB 2.0 Function Full-Speed: 1 ch
Serial I/F SCI: 4 ch; SCIF: 1 ch
RCAN-ET Bosch 2.0B active: 1 ch
DTC installed
DMAC: 8 ch
IIC: 1 ch master/slave mode
Bus state controller (BSC)
H-UDI/AUD: On-chip debugging functions
SH7216主要应用:
Industrial equipment: PLC, General-purpose inverters, AC servos, etc.
SH7216演示板
Renesas Demo Kit for SH7216
The Renesas Demo Kit for SH7216 (YRDKSH7216) is intended as a user-friendly introductory and demonstration tool for the SH7216 microcontroller. The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using the on-board E10A-USB emulator.
The Renesas Demo Kit for SH7216 may be connected to the host PC using the on-board E10A-USB on chip debugging interface.
The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.
The Renesas Demo Kit for SH7216 is also the hardware platform that is included in a special SH7216-specific edition of Micrium’s book on the µC/OS-III Real Time Kernel. The book and board combo targets serious programmers and college students who need to understand and create programs based on the timesaving features of a real-time kernel. Part I of the text covers the internals of the new µC/OS-III real-time kernel. The emphasis is on the internals, features, API calls, and where and how to use an RTOS, all presented in a clear and useful way, and accompanied by a wealth of diagrams. Part II provides specific examples for using µC/OS-III on the new Renesas SH7216 microcontroller.
This RDK is an evaluation and demonstration tool for Renesas SH2A and SH2A/7216 microcontrollers. The goal is to provide the user with a powerful debug and demonstration platform targeted at common applications. A set of human/machine interfaces are tightly integrated with the features of the SH2A/7216 and the software demonstration programs providing the user with an accessible platform to rapidly evaluate and customize.
SH7216演示板目标应用和主要特性:
Audio
o Stereo audio driver connected to the PWM interface
o On-board microphone to demonstrate sampling, FFT/FPU capabilities
o Volume Control Potentiometer
o Micro SD card interface for audio files
Motor Control
o 3 – Phase motor control algorithm representation with LEDs
o Motor control algorithm speed variation through volume control potentiometer Gaming
o 3 – Axis Accelerometer
o User pushbutton switches
o Develop and submit your sample programs to demonstrate these features to the online community: www.RenesasRulz.com dk7216
Communications
o 10/100 Ethernet Interface connected to an internal Ethernet MAC
o USB Interface connected to an internal USB controller
o RS-232 Interface
o CAN Interface (Not Loaded)
User Code and Application Debugging
o On-board E10A Debugger for high-quality source code debugging
o User circuit breadboard area
图1。SH7216演示板外形图
图2。SH7216演示板方框图
图3。SH7216演示板和PC连接图
图4。SH7216演示板电路图(1)
图5。SH7216演示板电路图(2)
图6。SH7216演示板电路图(3)
图7。SH7216演示板电路图(4)
图8。SH7216演示板电路图(5)
图9。SH7216演示板电路图(6)
图10。SH7216演示板电路图(7)
图11。SH7216演示板电路图(8)
图12。SH7216演示板电路图(9)
图13。SH7216演示板电路图(10)
图14。SH7216演示板电路图(11)
图15。SH7216演示板电路图(12)
图16。SH7216演示板电路图(13)
详情请见:
http://documentation.renesas.com/doc/products/mpumcu/doc/superh/r01uh0230ej_sh7216.pdf
和
http://am.renesas.com/products/tools/introductory_evaluation_tools/renesas_demo_kits/yrdksh7216/child/doc_child.jsp
以及
65615
来源:网络
