【资料分享】全志科技T507-H开发板规格书
2023年08月08日 16:35 发布者:Tronlong--
1 评估板简介创龙科技TLT507-EVM是一款基于全志科技T507-H处理器设计的4核ARM Cortex-A53国产工业评估板,主频高达1.416GHz,由核心板和评估底板组成。核心板CPU、ROM、RAM、电源、晶振等所有器件均采用国产工业级方案,国产化率100%。同时,评估底板大部分元器件亦采用国产工业级方案。核心板经过专业的PCB Layout和高低温测试验证,稳定可靠,可满足各种工业应用环境。
评估板接口资源丰富,引出三路网口、四路USB、双路CAN、双路RS485等通信接口,板载Bluetooth、WIFI、4G(选配)模块,同时引出MIPI CSI、HDMI OUT、LVDS LCD、TFT LCD、CVBS OUT、LINE OUT等音视频多媒体接口,支持双屏异显、G31 MP2 GPU、4K@60fps H.265视频硬件解码、4K@25fps H.264视频硬件编码,方便用户快速进行产品方案评估与技术预研。
![](https://www.eechina.com/data/attachment/forum/202308/08/163401m583ww546crhdsrw.jpg)
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102723863-1749456666.png)
![](https://www.eechina.com/data/attachment/forum/202308/08/163412exdad7dxxx8na8wx.jpg)
![](https://www.eechina.com/data/attachment/forum/202308/08/163204uthpoze02ed0bm02.png)
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102754633-1693337920.png)
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102804242-936737981.png)
![](https://www.eechina.com/data/attachment/forum/202308/08/163205fwmiycsacs1itqdc.png)
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102816775-972755766.png)
![](https://www.eechina.com/data/attachment/forum/202308/08/163205bl99369h85z89zvj.png)
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102827267-775326853.png)
![](https://www.eechina.com/data/attachment/forum/202308/08/163206kj4uqw8uww5b333o.png)
2 典型应用领域工业控制工业网关能源电力轨道交通仪器仪表
3 软硬件参数硬件框图
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102837641-1984794865.png)
![](https://www.eechina.com/data/attachment/forum/202308/08/163206guftrwfsn5ityisi.jpg)
图 7 评估板硬件框图
![](https://www.eechina.com/data/attachment/forum/202308/08/163453qxzyrmek31rxmk3l.jpg)
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102850253-616263785.png)
![](https://www.eechina.com/data/attachment/forum/202308/08/163456qd41c1sma54hd1yd.jpg)
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102902320-763314677.png)
硬件参数
表 1
CPU
全志科技T507-H,28nm
4x ARM Cortex-A53,主频高达1.416GHz
GPU:G31 MP2,支持OpenGL ES 1.0/2.0/3.2、Vulkan 1.1、OpenCL 2.0
Encoder:支持4K@25fps H.264视频硬件编码
Decoder:支持4K@60fps H.265视频硬件解码
ROM
8/16GByte eMMC
RAM
1/2GByte DDR4
LED
2x 电源指示灯(核心板1个,评估底板1个)
4x 用户可编程指示灯(核心板2个,评估底板2个)
KEY
1x PWRON按键
1x RESET按键
3x 用户输入按键
Video IN
1x MIPI CSI,支持8M@30fps或4 x1080p@25fps,30pin FFC连接器,间距0.5mm
Video OUT
1x HDMI OUT,支持4K@60fps
1x LVDS LCD电阻触摸屏接口,支持1080P@60fps,2x 15pin(显示)+ 6pin(背光)排针端子,间距2.0mm;4pin(触摸)排针,间距2.54mm
备注:LVDS LCD与TFT LCD引脚存在复用关系
1x TFT LCD电阻触摸屏接口,支持1080P@60fps,40pin FFC连接器,间距0.5mm
1x CVBS OUT,通过TVOUT引出,RCA莲花座
AUDIO
1x 3.5mm LINE OUT接口
Ethernet
1x ETH0 USB,通过USB3引出,RJ45接口,10/100Mbps自适应
1x ETH1 RMII,RJ45接口,10/100Mbps自适应
1x ETH2 RGMII,RJ45接口,10/100/1000Mbps自适应
USB
1x USB0 OTG0,USB2.0,Type-C接口
1x USB1 HOST,USB2.0,Type-A接口
2x USB2 HOST,USB2.0,通过USB2 HUB引出,Type-A接口
SDIO
1x SDIO,通过SDC1引出,2x 6pin排母,间距2.54mm
SD
1x Micro SD,通过SDC0引出
WIFI
1x WIFI模块,通过USB2 HUB引出,150Mbps速率
4G
1x 4G模块(选配),通过USB2 HUB引出,Mini PCIe母座
1x Micro SIM接口
Bluetooth
1x 蓝牙模块,通过UART5连接
UART
1x Debug UART,通过UART0引出,Type-C接口
2x RS485 UART,通过UART2、UART5引出,3pin绿色端子,间距3.81mm
1x RS232 UART,通过UART1引出,3pin绿色端子,间距3.81mm
SPI
1x SPI,通过SPI0引出,6pin白色端子,间距2.54mm
CAN
2x CAN,通过SPI1拓展引出,3pin绿色端子,间距3.81mm
GPADC1x 6pin排针端子,GPADC0~GPADC3,间距2.54mm
Watchdog1x 3pin排针配置接口,间距2.54mm,采用外置芯片方案
RTC
1x RTC座,适配纽扣电池ML2032(3V可充)、CR2032(3V不可充)
JTAG
1x JTAG接口,2x 7pin规格,间距2.0mm
EXPORT
1x EXPORT拓展接口,2x 4pin排母,间距2.54mm
BOOT SET
1x 1bit启动方式选择拨码开关
SWITCH
1x 电源拨动开关
POWER
1x 12V直流输入DC-005电源接口,可适配外径5.5mm、内径2.1mm电源插头
1x 12V直流输入,3pin绿色端子,间距3.81mm
软件参数
表 2
内核Linux-4.9.170、Linux-RT-4.9.170
文件系统Buildroot-201902、Ubuntu
图形界面开发工具Qt-5.12.5
软件开发套件提供V2.0_20220618
驱动支持LED
KEY
UART
CAN
SPI
PWM
DDR4
eMMC
SD
GPADC
Ethernet
USB2.0
4G/WIFI/Bluetooth
HDMI OUT
RTC
LINE OUT
MIPI CSI
CVBS OUT
TFT LCD
LVDS LCD
Touch Screen
4 开发资料(1) 提供核心板引脚定义、可编辑底板原理图、可编辑底板PCB、芯片Datasheet,协助国产元器件方案选型,缩短硬件设计周期;(2) 提供系统固化镜像、文件系统镜像、内核驱动源码,以及丰富的Demo程序;(3) 提供完整的平台开发包、入门教程,节省软件整理时间,让应用开发更简单。开发案例主要包括:
[*]ARM与FPGA通信开发案例(SPI/SDIO)
[*]8/16通道国产同步AD采集开发案例(与AD7606/AD7616管脚兼容)
[*]Linux、Linux-RT、Qt应用开发案例
[*]Docker容器技术、MQTT通信协议、Ubuntu操作系统演示案例
[*]4G/WIFI/Bluetooth开发案例
[*]IgH EtherCAT主站、SPI转CAN开发案例
[*]双屏异显、OpenCV、H.264/H.265视频硬件编解码开发案例
5 电气特性工作环境
表 3
环境参数
最小值
典型值
最大值
核心板工作温度
-40°C
85°C
核心板工作电压
5.0V
评估板工作电压
12.0V
功耗测试
表 4
类别工作状态电压典型值电流典型值功耗典型值
核心板空闲状态5.0V0.18A0.90W
满负荷状态5.0V0.41A2.05W
评估板空闲状态12.0V0.26A3.12W
满负荷状态12.0V0.34A4.08W
备注:测试数据与具体应用场景有关,仅供参考。
空闲状态:系统启动,评估板不接入其他外接模块,不执行程序。
满负荷状态:系统启动,评估板不接入其他外接模块,运行DDR压力读写测试程序,4个ARM Cortex-A53核心的资源使用率约为100%。
6 机械尺寸
表 5
核心板评估底板
PCB尺寸37mm*58mm120mm*171.4mm
PCB层数8层4层
PCB板厚1.6mm2.0mm
安装孔数量/4个
![](https://www.eechina.com/data/attachment/forum/202308/08/163214il1lidvupizgqrdi.png)
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102922169-1854226349.png)
![](https://www.eechina.com/data/attachment/forum/202308/08/163215b8cqwzvfv9gf77vz.png)
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102929899-428164423.png)
7 产品型号
表 6
型号
CPU
主频
eMMC
DDR4
TLT507-EVM-A1.0-64GE8GD-I-A1.0T507-H
1.416GHz
8GByte
1GByte
TLT507-EVM-A1.0-128GE16GD-I-A1.0T507-H
1.416GHz
16GByte
2GByte
TLT507-EVM-A1.0-64GE8GD-C-A1.0T507-H
1.416GHz
8GByte
1GByte
TLT507-EVM-A1.0-128GE16GD-C-A1.0T507-H
1.416GHz
16GByte
2GByte
备注:
(1) 标配为TLT507-EVM-A1.0-64GE8GD-I-A1.0。(2) SOM-TLT507-64GE8GD-I-A1.0、SOM-TLT507-128GE16GD-I-A1.0型号核心板为全国产,其他型号核心板为非全国产。
型号参数解释
![](https://img2023.cnblogs.com/blog/2812951/202308/2812951-20230808102944150-782701375.png)
![](https://www.eechina.com/data/attachment/forum/202308/08/163215zsms7p8bzmeuuazm.png)
8 评估板套件清单
表 7
名称
数量
备注
TLT507-EVM评估板
1个
12V电源适配器
1个
赠品
资料光盘/U盘
1套
赠品
Micro SD系统卡
1个
赠品
读卡器
1个
赠品
Type-C线
1条
赠品
直连网线
1条
赠品
HDMI线
1条
赠品
Type-C转接头
1个
赠品
2.4G天线
1条
赠品
9 技术服务(1)协助底板设计和测试,减少硬件设计失误;(2)协助解决按照用户手册操作出现的异常问题;(3)协助产品故障判定;(4)协助正确编译与运行所提供的源代码;(5)协助进行产品二次开发;(6)提供长期的售后服务。
10 增值服务主板定制设计核心板定制设计嵌入式软件开发项目合作开发技术培训
更多关于全志科技T507-H核心板的开发资料,欢迎在评论区留言,感谢您的关注~
