车载倒车影像显示 dc48V降压5V 替代MP9486A 低纹波电源IC
2023年06月15日 17:51    发布者:小郑
DESCRIPTION
  The SL9486A is a high-voltage, step-down, switching
regulator that delivers up to 2A of continuous current to the
load. It integrates a high-side, high-voltage, power
MOSFET with a current limit of 3.5A, typically. The wide 5V
to 100V input range accommodates a variety of step-down
applications, making it ideal for automotive, industry, and
lighting applications. Hysteretic voltage-mode control is
employed for very fast response.
  The switching frequency can be up to 1MHz, allowing for
small component size. Thermal shutdown and short-circuit
protection (SCP) provide reliable and fault-tolerant
operations. A 200μA quiescent current allows the SL9486A
to be used in battery-powered applications.
  The SL9486A is available in ESOP8 package.
FEATURES
  ・Wide 5V to 100V Input Range
  ・3.5A Typical Peak Switching Current Limit
  ・Hysteretic Control: No Compensation
  ・Up to 1MHz Switching Frequency
  ・PWM Dimming Control Input for LED Application
  ・Short-Circuit Protection (SCP) with Integrated
High-Side MOSFET
  ・200μA Quiescent Current
  ・Thermal Shutdown
  ・Packages: Pb-free Packages, ESOP8
APPLICATIONS
  ・Scooters, E-Bike Control Power Supplies
  ・Solar Energy Systems
  ・Automotive System Power
  ・Industrial Power Supplies
  ・High-Power LED Drivers
TYPICAL APPLICATION
