Qualcomm IPQ6010 / wifi 6E/industrial wifi router/wallystech router/DR6018
2023年03月07日 09:14    发布者:james121
Breif introductionIPQ6010 is a wireless communication SoC (systemon chip) developed by Qualcomm Technologies, Inc. DR6018 is developed on the basis of aIPQ6010,it has strong performance,it can deal withvarious scenarios in people’s lives.It features wide variety of peripheral interfaces to maximize designflexibility across a full range of home networking products. Specificationsa Quad-core ARM 64bit A53 @1.8GHzProcessor1GB (2x 512MB) DDR3L 16-bitinterface with 32-bit memory bus design1 x1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5GbpsEthernet PortM.2 (NGFF) “E Key” Socketwith MiniPCIe 3.0On-board 2x2 2.4GHz MUMIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chainOn-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max20dBm per chain4 x MMCXConnectorsAnd the nor flash is 8-32MB(normallyis 8MB),the nand flash is 256MB,the DDR is 1GB.When we use DR6018,Noticethese point.Thesupply voltage is 24-48VThe operating temperaturerange is -40°C to +70°C,is equal to -104°Fto +158°FThe storage temperaturerange is -45°C to +105°C,is equal to -113°Fto +221°FThe operating humidity rangeis 5% to +95% (non-condensing)Advantages1.high performance.It has a quad-coreARM @1.8GHz Processor,it can improveits fluency, can also provide up to 16560 DMIPScomputing power, built-in 6 multi-angle high gain antenna, 8 independent signalamplifier, to achieve 6600 megabit level of 160MH2 high frequency width.2.strong memory.You will be able to run multiple applicationsat the same time smoothly.3.fast datatransmission speed.It comes with two 2.4GHz radios and two 5GHz radios withfast transmission speed and stability.If you want tolearn more about the DR6018,welcome to click the link below.PRODUCTS_WallysCommunications (Suzhou ) Co., LTD
