ZCC1001E 100V 1.5A降压芯片
2022年10月25日 17:45 发布者:四维电子
Features 9V to 100V input voltage range
1.5A current limit
1A continuous load current
95% Peak Efficiency
400μA operating quiescent current
120V 400-mΩ high-side MOSFET
Peak Current mode control
150 kHz Fixed Frequency
Internal compensation for ease of use
Up to 92% duty cycle
0.8V voltage reference
1μA shutdown current
150ms Hiccup mode short circuit protection
Function
Thermal shutdown Function
ESOP-8 package
Applications
Charger in vehicle
Battery Chargers
Power adapter
Description
The ZCC1001E is a high voltage, non-synchronous
step-down converter operates over a wide range
input voltage 9V to 100V. The ZCC1001E
integrates a 120-V 400-mΩ high-side MOSFET.
The ZCC1001E delivers 1A continuous load
current with up to 95% efficiency. The ZCC1001E
operates with fixed frequency peak current control
with built-in compensation eliminates the need for
external components.
Cycle-by-cycle current limit in high-side MOSFET
protects the converter in an overload condition.
Hiccup mode protection is triggered if the over
current condition has persisted for longer than the
present time.
The ZCC1001E exhibits protection features that
protect the load from faults like under-voltage,
over-current and over-temperature.
The ZCC1001E is available in an ESOP-8 package
