QSDK IPQ5018, 802.11ax,QCN9074, industrial 2X2 2.4G router/support BT5.1
2022年10月10日 10:54    发布者:wallyswifi
MT7915/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW/QCA9531
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective router boards , wireless network cards,antenna ,enclosure and etc., Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
Skype/EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
Dual-core ARM 64bit A53@1.0GHz Processor512MB DDRL3L System Memory4MB NOR Flash, 128MB NAND Flash2x2 On-board 2.4GHz radio,up to 573Mbps physical Data RateSupport BT5.1M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
Absolute Maximum Rating
Parameter
RatingUnit
Supply Voltage
12V
Operating Temperature Range
-40 to +70oC
Storage Temperature Range
-45 to +105oC
Operating Humidity Range
5 to +95 (non-condensing)%
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm-Atheros IPQ5018
CPU Frequency
Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory
512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
4 x 1Gbps Ethernet Ports  or 1 x 1Gbps Ethernet Port & Poe
NGFF Slot
EMMC
4G/8G(optional)
USB /header
1x USB 3.0 Port
POE
NA
DC Jack
12V power supply
LED header
LED for power ,Wifi strength
Serial Port
support
Wireless
On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
BluetoothBT5.1
Nor Flash
8MB
Nand Flash
128 MB
DDR
512MB
Dimension
170mm x 120mm x 15mm
Since the use of smoke signals, flags and flashing mirrors in the pre – historic period, Wireless communication has been a part of human life and it is continuously evolving. Modern Wireless Communication i.e., using electrical signals and radio waves for communication has been around us for more than 100 years.
Another scenario where wireless communication got replaced by wired communication is Television broadcasting. In the early days, television signals were broadcasted using wireless radio transmitters. But this setup got replaced by cable television.
These two examples point out that with the development of technology, we always have to choose what's best for the situation i.e., in some areas we have to use wired communication whereas in the other, going for wireless may be a better option.
