TI ADS5294 80MSPS 8路医学图像解决方案
2011年11月22日 16:02 发布者:1640190015
TI公司的ADS5294是80MSPS/14位 8路ADC,具有低功耗,高SNR和低SFDR,以及连续过载恢复,适用于高性能系统设计. ADS5294具有数乁信号处理核,包括数字滤波器模块, 可编程数字增益0 dB到12 dB,内部和外接基准电压,1.8V工作电压,主要用在超声图像,通信设备和多路数据采集.本文介绍了ADS5294主要特性,方框图, 模拟输入模型和电路,评估模块测试图以及评估模块电路图,材料清单和PCB布局图.Using CMOS process technology and innovative circuit techniques, the ADS5294 is a low power 80MSPS 8-Channel ADC. Low power consumption, high SNR, low SFDR, and consistent overload recovery allow users to design high performance systems.
The ADS5294 has a digital processing block that integrates several commonly used digital functions for improving system performance. It includes a digital filter module that has built-in decimation filters (with low-pass, high-pass and band-pass characteristics).
The decimation rate is also programmable (by 2, by , or by 8). This makes it useful for narrow-band applications, where the filters can be used conveniently to improve SNR and knock-off harmonics, while at the same time reducing the output data rate. The device includes an averaging mode where two channels (or even four channels) can be averaged to improve SNR.
Serial LVDS outputs reduce the number of interface lines and enable the highest system integration. The digital data from each channel ADC can be output over one or two wires of LVDS output lines depending on the ADC sampling rate. This 2-wire interface helps keep the serial data rate low, allowing low cost FPGA based receivers to be used even at high sample rate. The ADC resolution can be programmed to 12 bit or 14 bit through register. A very unique feature is the programmable mapping module that allows flexible mapping between the input channels and the LVDS output pins. This helps greatly reduce the complexity of LVDS output routing and can potentially result in cheaper system boards by reducing the number of PCB layers.
The device integrates an internal reference trimmed to accurately match across devices. Best performance is expected to be achieved through the internal reference mode. The device can be driven with external references as well. The device is available in a 12 mm × 12 mm 80-pin QFP. It is specified over a –40°C to 85°C operating temperature range. ADS5294 is completely pin-to-pin and register compatible to ADS5292 QFP. It is specified over a –40°C to 85°C operating temperature range. ADS5294 is completely pin-to-pin and register compatible to ADS5292.
ADS5294主要特性:
Maximum Sample Rate: 80 MSPS/14-Bit
High Signal-to-Noise Ratio
75.5-dBFS SNR at 5 MHz/80 MSPS
78.2-dBFS SNR at 5 MHz/80 MSPS and Decimation Filter Enabled
84-dBc SFDR at 5 MHz/80 MSPS
Low Power Consumption
58 mW/CH at 50 MSPS
77 mW/CH at 80 MSPS (2 LVDS Wire Per Channel)
Digital Processing Block
Programmable FIR Decimation Filter and Oversampling to
Minimize Harmonic Interference
Programmable IIR High Pass Filter to Minimize DC Offset
Programmable Digital Gain: 0 dB to 12 dB
2- or 4- Channel Averaging
Flexible Serialized LVDS Outputs:
One or Two Wires of LVDS Output Lines per Channel
Depending on ADC Sampling Rate
Programmable Mapping Between ADC Input Channels and
LVDS Output Pins-Eases Board Design
Variety of Test Patterns to Verify Data Capture
by FPGA/Receiver
Internal and External References
1.8V Operation for Low Power Consumption
Low-Frequency Noise Suppression
ADS5294应用:
Ultrasound Imaging
Communication Applications
Multi-channel Data Acquisition
图1. ADS5294方框图
图2. ADS5294模拟输入模型
图3. ADS5294模拟输入驱动电路
ADS5294评估模块
This user’s guide gives a general overview of the evaluation module (EVM) and provides a general description of the features and functions to be considered while using this module. This manual is applicable to the ADS5294 analog-to-digital converters (ADC), which collectively are referred to as ADS529x. Use this document in combination with the respective ADC data sheet. The ADS529xEVM provides a platform for evaluating the ADC under various signal, clock, reference, and power supply conditions.
图4.ADS5294 EVM和TSW1250EVM硬件连接图
图5.ADS5294评估测试图
图6.ADS5294 EVM电路图(1)
图7.ADS5294 EVM电路图(2)
图8.ADS5294 EVM电路图(3)
图9.ADS5294 EVM电路图(4)
图10.ADS5294 EVM电路图(5)
图11.ADS5294 EVM电路图(6)
图12.ADS5294 EVM电路图(7)
图13.ADS5294 EVM电路图(8)
图14.ADS5294 EVM电路图(9)
ADS5294 EVM材料清单(BOM):
图15.ADS5294 EVM PCB布局图
详情请见:
51142和
51143
