TI DRV8301三相马达驱动解决方案
2011年09月27日 10:46 发布者:1640190015
TI公司的DRV8301是用于三相马达的栅极驱动器,包括三个半桥驱动器(每个可驱动两个N沟MOSFET),一个用于高边和一个用于低边的驱动器.支持2.3A沉电流和1.7A源峰值电流,单电源8V-60V工作,支持100%占空比.对外接MOSFET可编程过流保护,主要用在三相无刷DC马达和永磁同步马达,CPAP和泵,电动自行车,医院病床,轮椅以及电钻, 搅拌机和切碎机.本文介绍了DRV8301主要特性, 方框图, 应用案例电路图以及DRV8301-HC-C2-KIT评估板主要特性和马达驱动和控制解决方案框图.The DRV8301 is a gate driver IC for three phase motor drive applications. It provides three half bridge drivers, each capable of driving two N-type MOSFETs, one for the high-side and one for the low side. It supports up to 2.3A sink and 1.7A source peak current capability and only needs a single power supply with a wide range from 8 to 60V. The DRV8301 uses bootstrap gate drivers with trickle charge circuitry to support 100% duty cycle. The gate driver uses automatic hand shaking when high side FET or low side FET is switching to prevent current shoot through. Vds of FETs is sensed to protect external power stage during overcurrent conditions.
The DRV8301 includes two current shunt amplifiers for accurate current measurement.
DRV8301主要特性:
Operating Supply Voltage 8V–60V
2.3A Sink and 1.7A Source Gate Drive Current Capability
Integrated Dual Shunt Current Amplifiers With Adjustable Gain and Offset
Integrated Buck Converter to Support up to 1.5A External Load
Independent Control of 3 or 6 PWM Inputs
Bootstrap Gate Driver With 100% Duty Cycle Support
Programmable Dead Time to Protect External FETs from Shoot Through
Slew Rate Control for EMI Reduction
Programmable Overcurrent Protection of External MOSFETs
Support Both 3.3V and 5V Digital Interface
SPI Interface
Thermally Enhanced 56-Pin TSSOP Pad Down DCA Package
DRV8301应用:
3-Phase Brushless DC Motor and Permanent Magnet Synchronous Motor
CPAP and Pump
E-bike, Hospital Bed, Wheel Chair
Power Drill, Blender, Chopper
图1. DRV8301方框图
图2. DRV8301简化应用电路图
图3. DRV8301应用案例电路图
The DRV8301-HC-C2-KIT is a motor control evaluation kit for spinning three phase brushless DC and and brushless AC (BLAC) - often referred to as permanent magnet synchronous (PMSM) – motors with examples of both sensorless Field Oriented / Vector Control (FOC) and TI’s InstaSPIN-BLDC sensorless BLDC solution. The DRV8301-HC-C2-KIT is a high-performance, power-efficient, cost-effective platform that speeds development for quicker time to market. Applications include CPAP and pumps, E-bikes, E-scooters, medical pumps and drills, power tools, and robotics.
DRV8301-HC-C2-KIT评估板主要特性:
DRV8302 2.3A sink/1.7A source, three phase inverter with integrated buck converter for 1.5A external loads.
C2000 Piccolo F28035 MCU controlCARD – preflashed with code to spin motors using GUI
Isolated XDS100 Emulation
CCStudio v4.x Integrated Development Environment
图4.DRV8301-HC-C2-KIT评估板外形图
图5.马达驱动和控制解决方案框图
详情请见:
45618
