SL8335 Small Package PFM Control Step-UpDC/DC Converter
2021年06月25日 10:57 发布者:小郑
INTRODUCTIONThe SL8335 is a CMOS PFM-control step-up switching DC/DC converter. The VFM controller allows the duty ratio to be automatically switched according to the load, enabling products with a low ripple over a wide range, high efficiency, and high output current. With the SL8335, a step-up switching DC/DC converter can be configured by using an external coil, capacitor, and diode. The built-in MOSFET is turned off by a protection circui when the voltage at the LX pin exceeds the limit to prevent it from being damaged. This feature, along with the mini package and low current consumption, makes the SL8335 ideal for applications such as the power supply unit of portable equipment.
FEATURES
Low voltage operation: Startup at 0.9 V @IOUT = 1 mA
Work frequency: 300KHz
External parts: Coil, capacitor, diode
Accuracy of ±2%
High efficiency: 87%(typ.)
Shutdown function
Low ripple, Low noise
APPLICATIONS
Digital cameras
Electronic notebooks and PDAs
Portable CD/MD players
Cameras, video equipment,
Communications equipment
Power supply for microcomputers
BLOCK DIAGRAM
长期供应汽车车灯驱动芯片、摩托车车灯驱动芯片、手电筒驱动芯片、LED升降压恒流驱动芯片、恒压芯片、恒压方案、DC-DC电源管理芯片、MOS管
可免费提供样品测试!!!
