30V1.2A同步降压ic
2021年06月19日 10:12 发布者:小郑
SL1586 30V1.2A同步降压IC,dc-dc同步降压IC,降压IC,高压降压ICGeneral DescriptionThe SL1586 is a high frequency, synchronous, rectified, step-down, switch-mode converter with internal powerMOSFETs. It offers a very compact solution to achieve a 1.5A peak output current over a wide input supply range,with excellent load and line regulation.The SL1586 requires a minimal number of readily available, external components and is available in a space savingSOT23-6 package.Features
• Wide 4V to 30V Operating Input Range• 1.2A Continuous Output Current• 1.4MHz Switching Frequency• Short Protection with Hiccup-Mode• Built-in Over Current Limit• Built-in Over Voltage Protection• Force-PWM Mode• Internal Soft-Start• 200mΩ/150mΩ Low RDS(ON) Internal Power MOSFETs• Output Adjustable from 0.8V• No Schottky Diode Required• Integrated internal compensation• Thermal Shutdown• Available in SOT23-6 Package• -40°C to +85°C Temperature RangeTypical Application Circuit
