IR IRS2092 1700W单路D类音频功率放大方案
2011年06月01日 10:45 发布者:Liming
IR公司的 IRS2092是集成了PWM调制器和保护的高压高性能D类音频放大器,工作频率高达800kHz,±100 V额定电压是可提供500W输出功率,主要用在家庭影院,密你立体声系统,通用音频放大器等。本文介绍IRS2092主要特性,方框图,典型连接图,典型应用电路图以及1700W单路D类音频功率放大器框图,主要特性,电路图和材料清单。The IRS2092 is a high voltage, high performance Class D audio amplifier driver with PWM modulator and protection.
In conjunction with two external MOSFET and a few external components, a complete Class D audio amplifier with protection can be realized.
International Rectifier’s proprietary noise isolation technology allows high current gate drive stage and high speed low noise error amplifier reside on a single small silicon die.Open elements of PWM modulator section allow flexible PWM topology implementation.
IRS2092主要特性:
• Integrated analog input Class D audio amplifier driver in a small 16 pin package
• Floating inputs enable easy half bridge implementation
• Programmable bidirectional over-current protection with self-reset function
• Programmable preset deadtime for improved THD performances
• Start and stop click noise reduction
• High noise immunity
• ±100 V ratings deliver up to 500 W in output power
• Operates up to 800 kHz
• RoHS compliant
IRS2092典型应用:
• Home theater systems
• Mini component stereo systems
• Powered speaker systems
• General purpose audio power amplifiers
图1。IRS2092方框图
图2。IRS2092典型连接图
图3。IRS2092典型应用电路图
1700W单路D类音频功率放大器
IRAUDAMP9:1.7 kW / 2-Ω Single Channel Class D Audio Power Amplifier Using the IRS2092S and IRFB4227
The IRAUDAMP9 reference design is a single-channel 1.7-kW ( @ 2Ω load) half-bridge Class D audio power amplifier. This reference design demonstrates how to use the IRS2092S Class D audio controller and external gate buffer, to implement protection circuits, and design an optimum PCB layout using the IRFB4227 (x 2 Pairs) TO-220 MOSFETs. This reference design may require additional heatsink or fan for normal operation (one-eighth of continuous rated power). The reference design provides all the required housekeeping power supplies for ease of use. The 1-channel design is capable of delivering higher than its rated power with provision of larger heat sink ( Rth <2° C / W).
1700W单路D类音频功率放大器主要应用:
• Pro-Audio amplifiers
• Powered speakers
• Active Sub-woofers
• P.A. Systems
• Car audio amplifiers
Musical Instrument amplifier
1700W单路D类音频功率放大器主要特性:
Output Power: 1.7 kW Single channel (2 Ω load, 1kHz, THD+N=10%),
Residual Noise: 290μV, IHF-A weighted, AES-17 filter
Distortion: 0.07% THD+N @ 600W, 2Ω
Efficiency: 97% @ 1.7 kW, 2Ω
Multiple Protection Features: Output Over-current protection (OCP), high side and low side
Input Over-voltage protection (OVP),
Input Under-voltage protection (UVP),
Output DC-offset protection (DCP),
Over-temperature protection (OTP)
PWM Modulator: Self-oscillating half-bridge topology with optional clock synchronization
图4。1700W单路D类音频功率放大器功能方框图
图5。1700W单路D类音频功率放大器外形图
图5。IRS2092S保护电路功能框图
图6。1700W单路D类音频功率放大器测试图
图7。1700W单路D类音频功率放大器电路框图
图8。1700W单路D类音频功率放大器电路图(1)
图9。1700W单路D类音频功率放大器主板输入/输出电源连接图
图10。1700W单路D类音频功率放大器主板电路图(1)
图9。1700W单路D类音频功率放大器子板电路图
IRAUDAMP9主板材料清单:
IRAUDAMP9子板材料清单:
IRAUDAMP9机械零件清单:
详情请见:
http://www.irf.com/product-info/datasheets/data/irs2092.pdf
和
http://www.irf.com/technical-info/refdesigns/iraudamp9.pdf
