AK4118AEQ音频组件AK4104ET光纤同轴数字音频接口AK4113VF/AK4103AVF
2020年07月24日 17:13 发布者:soundbaraudio
AKM 产品 音频组件 数字音频接口AK4103AVF MP 2 24 28 192 4.75 5.0 5.25 4-wire / HW Automotive grade -40 to 85 VSOP 24 AK4113VF MP 2 24 8 216 6:1 2.7 3.3 3.6 4-wire / I2C / HW Automotive grade -40 to 85 VSOP 30 AK4104ET MP 2 24 8 192 2.7 3.3 3.6 4-wire -20 to 85 TSSOP 16 AK4118AEQ MP 2 2 24 8 192 8:1 2.7 3.3 3.6 4-wire / I2C / HW -10 to 70 LQFP 48
AKM 产品 音频组件 数字音频接口Digital Audio Interfaces技术商务151 1247 6010 莫先生The AK410X/1X series is a 24-bit digital audio transmitters/transceivers/receivers. The channel status supports both consumer and professional formats and the AK410X/1X series has automatic detect function of Non-PCM data streams such as AC-3 and MPEG, capable to realize a AC-3 system with a multi-channeled CODEC. Dedicated parallel pins or serial μP interface is available for setting the device. The AK410X/1X series is housed in a small package, saving board space.
LineupDigital Audio InterfacesPart NumberPartStatusNumber of Channels (DIR)Number of Channels (DIT)Bitsfs (MIN.)fs (TYP.)fs (MAX.)Digital Audio IF RX MUXPower Supply Voltage (MIN.)Power Supply Voltage (TYP.)Power Supply Voltage (MAX.)Control InterfaceOtherOperatingTemperature[℃]DevicePackageNumberof PinsAKM 产品 音频组件 数字音频接口AK4103AVF MP 2 24 28 192 4.75 5.0 5.25 4-wire / HW Automotive grade -40 to 85 VSOP 24 AK4113VF MP 2 24 8 216 6:1 2.7 3.3 3.6 4-wire / I2C / HW Automotive grade -40 to 85 VSOP 30 AK4104ET MP 2 24 8 192 2.7 3.3 3.6 4-wire -20 to 85 TSSOP 16 AK4118AEQ MP 2 2 24 8 192 8:1 2.7 3.3 3.6 4-wire / I2C / HW -10 to 70 LQFP 48 AKM’s audio D/A converters (DACs) provide solutions for high quality audio system with the original digital-analog mixing technology.They are used in variety of applications such as AV receivers, set-top boxes, speaker systems, digital TVs and car-entertainment systems, contributing to the sound quality and power consumption improvements and reducing external parts. Part NumberPartStatusNumber of ChannelsAnalog Output TypeBitsTHD+NS/NPower Supply Voltage (MIN.)Power Supply Voltage (TYP.)Power Supply Voltage (MAX.)2Vrms Line DriverHeadphone AmplifierOtherOperatingTemperature[℃]DevicePackageNumberof Pins AK4432VT MP 2 Single 32 -91 108 3.0 3.3 3.6 VELVETSOUND, Automotive grade -40 to 105 TSSOP 16 AK4377ECB MP 2 Single 32 -109 128 1.7 1.8 1.9 Yes VELVETSOUND -40 to 85 WLCSP 36 AK4377AECB MP 2 Single 32 -107 125 1.7 1.8 1.9 Yes VELVETSOUND -40 to 85 WLCSP 36 AK4490EN MP 2 Differential 32 -112 120 (123*) 4.75 / 3.0 5.0 / 3.3 5.25 / 3.6 VELVETSOUND -40 to 85 HVQFN 48 AK4498EQ NEW 2 Differential 6 -116 128 4.75 / 3.0 / 1.7 5.0 / 3.3 / 1.8 5.25 / 3.6 / 1.98 VELVETSOUND -40 to 85 HTQFP 64 AK4430ET MP 2 Single 24 -91 104 3.0 3.3 3.6 Yes Ground-referenced output -20 to 85 TSSOP 16 AK4495SEQ MP 2 Differential 32 -101 123/120 4.75 / 3.0 5.0 / 3.3 7.2 / 3.6 VELVETSOUND -40 to 85 LQFP 44 AK4490EQ MP 2 Differential 32 -112 120 (123*) 4.75 / 3.0 5.0 / 3.3 7.2 / 3.6 VELVETSOUND -40 to 85 LQFP 48 AK4436VN MP 6 Single 32 -91 108 3.0 3.3 3.6 VELVETSOUND, Automotive grade -40 to 105 HWQFN 32 AK4493EQ MP 2 Differential 32 -113 123 (126*) 4.75 / 3.0 / 1.7 5.0 / 3.3 / 1.8 5.25 / 3.6 / 1.98 VELVETSOUND -40 to 85 LQFP 48 AK4454VN MP 4 Differential 32 -107 115 / 111 3.0 / 3.0 5.0 / 3.3 5.5 / 3.6 VELVETSOUND, Automotive grade -40 to 105 HWQFN 32 AK4331ECB MP 2 Single 32 -100 109 1.7 1.8 1.9 Yes SRC , VELVETSOUND -40 to 85 WLCSP 36 AK4458VN MP 8 Differential 32 -107 115 / 111 3.0 / 3.0 5.0 / 3.3 5.5 / 3.6 VELVETSOUND, Automotive grade -40 to 105 HVQFN 48 AK4497EQ MP 2 Differential 32 -116 128 (131*) 4.75 / 3.0 / 1.7 5.0 / 3.3 / 1.8 5.25 / 3.6 / 1.98 VELVETSOUND -40 to 85 HTQFP 64 AK4495EQ MP 2 Differential 32 -101 123 / 120 4.75 / 3.0 5.0 / 3.3 7.2 / 3.6 VELVETSOUND -40 to 85 LQFP 44 AK4499EQ MP 4 Differential 32 -124 134 (140*) 4.75 / 3. Part NumberPartStatusNumber of ChannelsAnalog Input TypeBitsMax fsTHD+NS/NPower Supply Voltage (MIN.)Power Supply Voltage (TYP.)Power Supply Voltage (MAX.)PLLMicrophone AmplifierOtherOperatingTemperature[℃]DevicePackageNumberof PinsAK5536VN MP 6 Differential 32 768 -103 111(118*) 3.0 3.3 3.6 VELVETSOUND, Automotive grade -40 to 105 HVQFN 64 AK5552VN MP 2 Differential 32 768 -106 115(118*) 4.5 5.0 5.5 VELVETSOUND, Automotive grade -40 to 105 HVQFN 48 AK5730VQ MP 4 Single / Differential 24 48 -92 100 3.0 3.3 3.6 Yes Mic-diagnostics, Cascade TDM I/F, Automotive grade -40 to 105 LQFP 48 AK5706ECB NEW 2 Single / Differential 24 192 -90 105 1.7 / 3.0 1.8 / 3.3 1.9 / 3.6 Yes Yes AAA, Audio buffer, Cascade TDM I / F -40 to 85 WLCSP 32 AK5736VN MP 6 Differential / Single 24 192 -92 100 3.0 3.3 3.6 Yes Mic-diagnostics, Cascade TDM I/F, Automotive grade -40 to 105 HVQFN 48 AK5574EN MP 4 Differential 32 768 -112 121 (127*) 4.75 5.00 5.25 VELVETSOUND -40 to 85 HVQFN 48 AK5720VT MP 2 Single 24 96 -94 102 2.7 3.0 or 5.0 5.5 Yes Cascade TDM I / F, Automotive grade -40 to 105 TSSOP 16 AK5704EN MP 4 Single / Differential 32 192 -90 105 1.7 / 3.0 1.8 / 3.3 1.9 / 3.6 Yes Yes VAD, ALC, Cascade TDM I/F -40 to 85 HWQFN 28 AK5556VN MP 6 Differential 32 768 -106 115 (122*) 4.5 5.0 5.5 VELVETSOUND, Automotive grade -40 to 105 HVQFN 64 AK5534VN MP 4 Differential 32 768 -103 111 (117*) 3.0 3.3 3.6 VELVETSOUND, Automotive grade -40 to 105 HVQFN 48 AK5558VN MP 8 Differential 32 768 -106 115 (124*) 4.5 5.0 5.5 VELVETSOUND, Automotive grade -40 to 105 HVQFN 64 AK5538VN MP 8 Differential 32 768 -103 111 (120*) 3.0 3.3 3.6 VELVETSOUND, Automotive grade -40 to 105 HVQFN 64 AK5578EN MP 8 Differential 32 768 -112 121 (130*) 4.75 5.00 5.25 VELVETSOUND -40 to 105 HVQFN 64 AK5522VN MP 2 Single/Differential 32 192 -98 108 4.5/3.0 5.0/3.3 5.5/3.6 Yes Yes VELVETSOUND, Automotive grade -40 AKM 产品 音频组件 音频编译码器 LineupAudio CODECsPart NumberPartStatusNumber of Channels (AD)Number of Channels (DA)BitsS/N (AD)S/N (DA)THD (AD)THD (DA)Power Supply Voltage (MIN.)Power Supply Voltage (TYP.)Power Supply Voltage (MAX.)Microphone AmplifierSpeaker AmplifierOtherOperatingTemperature[℃]DevicePackageNumberof PinsAK4627VQ MP 4 6 24 102 106 -92 -90 4.5 5.0 5.5 Automotive grade -40 to 105 LQFP 48 AK4637EN MP 1 1 24 95 94 -84 -85 2.8 3.3 5.5 Yes Monaural SPK-Amp: 1W Output -40 to 85 HWQFN 20 AK4621EF MP 2 2 24 115 115 -102 -100 4.75 / 3.0 5.0 / 3.3 5.25 / 3.6 -10 to 70 VSOP 30 AK4637VN MP 1 1 24 95 94 -84 -85 2.8 3.3 5.5 Yes Monaural SPK-Amp: 1W Output, Automotive grade -40 to 85 HWQFN 20 AK4616VQ MP 3 5 24 99 105 -88 -95 3.0 / 1.7 3.3 / 1.8 3.6 / 1.9 Yes Automotive grade -20 to 85 LQFP 48 AK4558EN MP 2 2 32 108 108 -92 -100 2.4 3.3 3.6 PLL VELVETSOUND -40 to 105 HWQFN 28 AK4556VT MP 2 2 24 103 106 -91 -90 2.7 3.0 3.6 Automotive grade -40 to 85 TSSOP 20 AK4695ECB MP 4 4 24 103 95 -93 -87 2.7 / 1.6 2.8 / 1.8 3.5 / 2.0 Yes Monaural -30 to 85 WLCSP 42 AK4958EG MP 2 2 24 96 92 -85 -85 2.8 / 1.6 3.3 / 1.8 3.6 / 2.0 Yes Monaural Auto Wind Noise Cut -30 to 85 VBGA 32 AK4634EN MP 1 1 16 89 93 -84 -85 2.2 3.3 3.6 Yes Monaural -30 to 85 HWQFN 32 AK4940VN MP 1 1 24 90 90 -80 -80 3 3.6 Yes Analog Direct Path, Automotive grade -40 to 105 HWQFN 24 AK4628AVQ MP 2 8 24 102 106 -92 -90 4.5 5.0 5.5 Automotive grade -40 to 85 LQFP 44 AK4954AEN MP 2 2 32 100 100 -88 -80 2.5 3.3 3.5 Yes Monaural -30 to 85 HWQFN 32 AK4613VQ MP 4 12 24 104 108 -97 -100 3.0 / 1.6 3.3 / 1.8 3.6 / 2.0 Automotive grade -40 to 105 LQFP 80 AK4951AEN MP 2 2 24 96 97 -85 -85 2.8 3.3 3.5 Yes Monaural Auto Wind Noise Cut, SPK-Amp: 1W Output -40 to 85 HWQFN 32 AK4953AEN MP 2 2 24 96 96 -85 -80 2.85 3.3 3.5 Yes Monaural -30 to 85 HWQFN 36 AK4957EN MP 2 2 24 96 92 -85 -85 2.8 / 1.6 3.3 / 1.8 3.6 / 2.0 Yes Monaural -30 to 85 HWQFN 32 AK4633VN MP 1 1 16 85 93 -84 -85 2.2 3.3 3.6 Yes Monaural Automotive grade -40 to 85 HWQFN 24 AK4678ECB MP 2 2 24 92 92 -80 -80 1.7 1.8 2.0 Yes Monaural SPK-Amp: 1W Output -30 to 85 WLCSP 49 AK4528VM MP 2 2 24 108 110 -94 -94 4.75 5.0 5.25 -40 to 85 SSOP 28 2020/07/21AKM develops ultra-low power intelligent system wakeup ADC with integrated Acoustic Activity Analyzer consuming only 30μA2020/06/02AKM releases AK8781, the smallest ever latch-type Hall IC with 60% smaller package size than its conventional product2020/05/26AKM releases 5.9GHz transceiver IC with IF filter and power amplifier for supporting Japanese ETC2.0/ETC system2020/05/13AKM releases compact and premium D/A converter using audio-optimized LSI manufacturing process2020/03/25AKM releases low latency 4ch A/D converter for automotive ANCs
