在EK-STM32F学习套件上实现了USB-DFU设备功能
2009年11月25日 15:50 发布者:STM32
首先在ST官网上下载了STM32的USB开发套件地址:http://www.st.com/stonline/products/support/micro/files/um0424.zip由于此开发套件基于ST的官方开发板,与EK-STM32F的电路有所不同。
比较了一下,不同之处在于
1, 官方的开发套件使用PD.09作为USB识别使能线,而EK-STM32F使用PD.08。
2, 官方的开发套件通过PB.09来判断是否进入DFU模式, 而EK-STM32F的按键使用了PD.03和PD.04。
3, EK-STM32F没有接外部SPI Flash, 所以只能更新内部flash。
因此修改代码如下:
void DFU_Button_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
/* Enable GPIOD clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
/* Configure PD.04 as input floating (Key push-button on EK-STM32F) */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOD, &GPIO_InitStructure);
u8 DFU_Button_Read (void)
/* Return the value of PD.04 */
return GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_4);
void Set_System(void)
FLASH_Unlock();
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
/* PD.08 used as USB pull-up --> EK-STM32F */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
USB_Cable_Config (DISABLE);
// SPI_FLASH_Init();
USB_Cable_Config (ENABLE);
void USB_Cable_Config (FunctionalState NewState)
if (NewState != DISABLE)
GPIO_ResetBits(GPIOD, GPIO_Pin_8);
else
GPIO_SetBits(GPIOD, GPIO_Pin_8);
修改后烧入EK-STM32F学习板,果然能识别出一个DFU设备。
请下载移植到EKSTM32F的USB开发套件后把他们放到同一个目录下(STM32F10xUSBLib),方法如下:
1)自建一个STM32F10xUSBLib目录
2)下载这个文件4701并解压到STM32F10xUSBLib目录
3)下载这个文件4702并解压到STM32F10xUSBLib目录
最终目录结构应为:
STM32F10xUSBLib
FWLib
library
inc
src
USBLib
demos
Device_Firmware_Upgrade 本帖介绍的DFU演示软件
JoyStickMouse
Mass_Storage
Virtual_COM_Port
library
inc
src
在ST官网下载PC端驱动和应用程序地址:http://www.st.com/stonline/products/support/micro/files/um0412.zip
安装后运行DfuSeDemo(V2.1),在DFU Device中识别到一个STM Device in DFU Mode设备。
选择Internal Flash,选择STM32 USB开发套件的DFU DEMO中的任意image, 按下Upgrade按键。
出现一个对话框:擦除操作失败
DFU的代码我曾经在ST的官方开发板上测试过,没有出过错,那么现在的错误在哪里呢?
拿了USB分析仪,看USB线上数据,发现设备总在某次的DFU_GETSTATUS请求后响应一个STALL信号,导致出错。
根据USB DFU协议(下载地址: http://www.usb.org/developers/devclass_docs/DFU_1.1.pdf), 对DFU_GETSTATUS的响应应该由:bStatus(1byte) + bwPollTimeout(3Bytes,以ms为单位) + bState(1byte) + iString(1byte)组成,但看USB线上数据,设备的响应为:00 00 00 00 04 00,显然是要求的Poll Time时间太短,导致设备在擦除flash的等待时间内无法响应PC端的又一个请求。
仔细看u8 *GETSTATUS(u16 Length)的代码:
case STATE_dfuDNLOAD_SYNC:
if (wlength != 0)
DeviceState = STATE_dfuDNBUSY;
DeviceStatus = DeviceState;
if ((wBlockNum == 0) && (Load_Buffer == CMD_ERASE))
if (Pointer < 0x800000) /* 64K sectors of SPI Flash */
DeviceStatus = 0xDC; /* 1.5 seconds */
DeviceStatus = 0x05;
DeviceStatus = 0x00;
<=====================此处值得商榷
else
DeviceStatus = (wlength >> 8) * 2 ; /* Nb of Pages(of 256 )* 2ms */
DeviceStatus = 0;
DeviceStatus = 0;
else /* (wlength==0)*/
DeviceState = STATE_dfuDNLOAD_IDLE;
DeviceStatus = 0;
DeviceStatus = 0;
DeviceStatus = 0;
break;
代码在分析到当前操作为CMD_ERASE命令时,仅仅对SPI FLASH的操作定义了Poll的时间,而对内部flash的操作没有定义,因此设备直接返回了0。
察看STM32F103的Datasheet:
Page(1KB)erase time 为 Min20ms, Max40ms
Word programming time 为 Min20us, Max40us
修改代码如下:
if (wlength != 0)
else {
DeviceStatus = 0x28;
else
// DeviceStatus = (wlength >> 8) * 2 ; /* Nb of Pages(of 256 )* 2ms */
DeviceStatus = (wlength >> 8) * 10 ; /* Nb of Pages(of 256 )* 10ms */
DeviceStatus = 0;
DeviceStatus = 0;
DeviceStatus = 0;
DeviceStatus = 0;
DeviceStatus = 0;
break;
修改后重新烧录代码,重新执行Upgrade操作,OK。
至于原先在测试DFU代码时为何没有出错,我认为是因为我刚新换了电脑的缘故,PC跑的快了,愿意等待的时间短了。。。。。
DUF搞完,开始考虑image的生成。
PC端的应用程序除了DfuSeDemo,还有个DfuFileManage(V2.1),能将S19,HEX和BIN文件生成DFU文件。
随便找了个LCD的demo,修改lnkarm_flash.xcl文件如下:
// Code memory in FLASH
-DROMSTART=0x8003000
-DROMEND=0x801FFFF
修改stm32f10x_nvic.h文件对于Vector Table地址的定义如下:
#define NVIC_VectTab_RAM ((u32)0x20000000)
#define NVIC_VectTab_FLASH ((u32)0x08003000)
使用IAR生成raw-binary文件。
运行DFU File Manager Generation程序, 选择Mullti Bin injection,输入刚才生成的bin文件,选择地址为0x08003000, 生成OK。
运行DfuSeDemo程序,将刚才生成的DFU文件烧录到内部flash中。
按下Reset按键,LCD DEMO程序如愿跑了起来,再次按下Reset按键,同时按下KEY3,PC识别到一个DFU设备。
至此,DFU设备在EK-STM32F学习板上移植成功。
最初发表日期:2008-4-12
