有人研究过ST官方I2C中断代码吗
2009年06月12日 12:35 发布者:hsia
连续发送两个字节数据:Tx1_Idx = 0;
I2cNumbOfBytes2Tansmit = 2;
I2C1_Buffer_Tx = 0x64;
I2C1_Buffer_Tx = 0x00;
Direction = Transmitter;
I2C_GenerateSTART(I2C1, ENABLE);
我的中断代码:
void I2C1_EV_IRQHandler(void)
switch (I2C_GetLastEvent(I2C1))
case I2C_EVENT_MASTER_MODE_SELECT: /* EV5 */
/* Master Transmitter ----------------------------------------------*/
/* Send slave Address for write */
if(Direction == Transmitter)
I2C_Send7bitAddress(I2C1, 0x64, I2C_Direction_Transmitter);
else
/* Master Receiver -------------------------------------------------*/
/* Send slave Address for read */
I2C_Send7bitAddress(I2C1, 0x65, I2C_Direction_Receiver);
break;
/* Master Transmitter --------------------------------------------------*/
/* Test on I2C1 EV6 and first EV8 and clear them */
case I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED:
/* Send the first data */
I2C_SendData(I2C1, I2C1_Buffer_Tx);
I2cNumbOfBytes2Tansmit--;
if (I2cNumbOfBytes2Tansmit == 0)
/* In order to not have a TxE event Interrupt */
I2C_ITConfig(I2C1, I2C_IT_BUF, DISABLE);
break;
/* Test on I2C1 EV8 and clear it */
case I2C_EVENT_MASTER_BYTE_TRANSMITTING: /* Without BTF, EV8 */
break;
case I2C_EVENT_MASTER_BYTE_TRANSMITTED: /* With BTF EV8-2 */
I2C_ITConfig(I2C1, I2C_IT_BUF, ENABLE);
I2C_GenerateSTOP(I2C1, ENABLE);
Direction = Receiver;
break;
default:
break;
现在发现进不了EV8-2中断,如果改成发送一个字节数据可以进入该中断。
仔细研究了datasheet,找不出任何问题。
PS:外挂的器件是rx8025实时时钟芯片。
香水城到不到这里的?21icbbs这几天一直上不去,非常之郁闷!
有时候官方的东西也不能信
害人的东西存在于各个世界角落
