PCB设计中专业英译术语之基材的材料
2018年05月07日 14:05 发布者:板儿妹0517
1. A阶树脂:A-stage resin 2. B阶树脂:B-stage resin 3. C阶树脂:C-stage resin 4. 环氧树脂:epoxy resin 5. 酚醛树脂:phenolic resin 6. 聚酯树脂:polyester resin 7. 聚酰亚胺树脂:polyimide resin 8. 双马来酰亚胺三嗪树脂:bismaleimide-triazine resin 9. 丙烯酸树脂:acrylic resin 10. 三聚氰胺甲醛树脂:melamine formaldehyde resin 11. 多官能环氧树脂:polyfunctional epoxy resin 12. 溴化环氧树脂:brominated epoxy resin 13. 环氧酚醛:epoxy novolac 14. 氟树脂:fluroresin 15. 硅树脂:silicone resin 16. 硅烷:silane 17. 聚合物:polymer 18. 无定形聚合物:amorphous polymer 19. 结晶现象:crystalline polamer 20. 双晶现象:dimorphism 21. 共聚物:copolymer 22. 合成树脂:synthetic 23. 热固性树脂:thermosetting resin 24. 热塑性树脂:thermoplastic resin 25. 感旋光性树脂:photosensitive resin 26. 环氧当量:weight per epoxy equivalent (WPE) 27. 环氧值:epoxy value 28. 双氰胺:dicyandiamide 29. 粘结剂:binder 30. 胶粘剂:adesive 31. 固化剂:curing agent 32. 阻燃剂:flame retardant 33. 遮光剂:opaquer 34. 增塑剂:plasticizers 35. 不饱和聚酯:unsatuiated polyester 36. 聚酯薄膜:polyester 37. 聚酰亚胺薄膜:polyimide film (PI) 38. 聚四氟乙烯:polytetrafluoetylene (PTFE) 39. 聚全氟乙烯丙烯薄膜:perfluorinated ethylene-propylene copolymer film (FEP) 40. 增强材料:reinforcing material 41. 玻璃纤维:glass fiber 42. E玻璃纤维:E-glass fibre 43. D玻璃纤维:D-glass fibre 44. S玻璃纤维:S-glass fibre 45. 玻璃布:glass fabric 46. 非织布:non-woven fabric 47. 玻璃纤维垫:glass mats 48. 纱线:yarn 49. 单丝:filament 50. 绞股:strand 51. 纬纱:weft yarn 52. 经纱:warp yarn 53. 但尼尔:denier 54. 经向:warp-wise 55. 纬向:weft-wise, filling-wise 56. 织物经纬密度:thread count 57. 织物组织:weave structure 58. 平纹组织:plain structure 59. 坏布:grey fabric 60. 稀松织物:woven scrim 61. 弓纬:bow of weave 62. 断经:end missing 63. 缺纬:mis-picks 64. 纬斜:bias 65. 折痕:crease 66. 云织:waviness 67. 鱼眼:fish eye 68. 毛圈长:feather length 69. 厚薄段:mark 70. 裂缝:split 71. 捻度:twist of yarn 72. 浸润剂含量:size content 73. 浸润剂残留量:size residue 74. 处理剂含量:finish level 75. 浸润剂:size 76. 偶联剂:couplint agent 77. 处理织物:finished fabric 78. 聚酰胺纤维:polyarmide fiber 79. 聚酯纤维非织布:non-woven polyester fabric 80. 浸渍绝缘纵纸:impregnating insulation paper 81. 聚芳酰胺纤维纸:aromatic polyamide paper 82. 断裂长:breaking length 83. 吸水高度:height of capillary rise 84. 湿强度保留率:wet strength retention 85. 白度:whitenness 86. 陶瓷:ceramics 87. 导电箔:conductive foil 88. 铜箔:copper foil 89. 电解铜箔:electrodeposited copper foil (ED copper foil) 90. 压延铜箔:rolled copper foil 91. 退火铜箔:annealed copper foil 92. 压延退火铜箔:rolled annealed copper foil (RA copper foil) 93. 薄铜箔:thin copper foil 94. 涂胶铜箔:adhesive coated foil 95. 涂胶脂铜箔:resin coated copper foil (RCC) 96. 复合金属箔:composite metallic material 97. 载体箔:carrier foil 98. 殷瓦:invar 99. 箔(剖面)轮廓:foil profile 100. 光面:shiny side 101. 粗糙面:matte side 102. 处理面:treated side 103. 防锈处理:stain proofing104. 双面处理铜箔:double treated foil以上即是PCB设计中专业英译术语之基材的材料,下期预告:PCB设计中专业英译术语之设计,更多更多行业信息可查阅快点学院订阅号:eqpcb_cp。http://www.eqpcb.com/shop/r/gou/images/img_93.jpg
