PCB设计中专业英译术语之综合词汇
2018年04月27日 09:34 发布者:板儿妹0517
1. 板:board2. 印制板:printed board
3. 印制电路:printed circuit
4. 印制线路:printed wiring
5. 印制线路板:printed wiring board(PWB)
6. 印制板电路:printed circuit board (PCB)
7. 印制接点:printed contact
8. 印制组件:printed component
9. 印制板装配:printed board assembly
10. 单面印制板:single-sided printed board(SSB)
11. 双面印制板:double-sided printed board(DSB)
12. 多层印制板:mulitlayer printed board(MLB)
13. 多层印制电路板:mulitlayer printed circuit board
14. 多层印制线路板:mulitlayer prited wiring board
15. 刚性印制板:rigid printed board
16. 刚性单面印制板:rigid single-sided printed borad
17. 刚性双面印制印制板装配:printed board assembly
18. 刚性多层印制板:rigid multilayer printed board
19. 挠性多层印制板:flexible multilayer printed board
20. 挠性印制板:flexible printed board
21. 挠性单面印制板:flexible single-sided printed board
22. 挠性双面印制板:flexible double-sided printed board
23. 挠性印制电路:flexible printed circuit (FPC)
24. 挠性印制线路:flexible printed wiring
25. 刚性印制板:flex-rigid printed board, rigid-flex printed board
26. 刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed
27. 刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board
28. 齐平印制板:flush printed board
29. 金属芯印制板:metal core printed board
30. 金属基印制板:metal base printed board
31. 多重布线印制板:mulit-wiring printed board
32. 陶瓷印制板:ceramic substrate printed board
33. 导电胶印制板:electroconductive paste printed board
34. 模塑电路板:molded circuit board
35. 模压印制板:stamped printed wiring board
36. 顺序层压多层印制板:sequentially-laminated mulitlayer
37. 散线印制板:discrete wiring board
38. 微线印制板:micro wire board
39. 积层印制板:buile-up printed board
40. 积层多层印制板:build-up mulitlayer printed board (BUM)
41. 积层挠印制板:build-up flexible printed board
42. 表面层合电路板:surface laminar circuit (SLC)
43. 埋入凸块连印制板:B2it printed board
44. 多层膜基板:multi-layered film substrate(MFS)
45. 层间全内导通多层印制板:ALIVH multilayer printed board
46. 载芯片板:chip on board (COB)
47. 埋电阻板:buried resistance board
48. 母板:mother board
49. 子板:daughter board
50. 背板:backplane
51. 裸板:bare board
52. 键盘板夹心板:copper-invar-copper board
53. 动态挠性板:dynamic flex board
54. 静态挠性板:static flex board
55. 可断拼板:break-away planel
56. 电缆:cable
57. 挠性扁平电缆:flexible flat cable (FFC)
58. 薄膜开关:membrane switch
59. 混合电路:hybrid circuit
60. 厚膜:thick film
61. 厚膜电路:thick film circuit
62. 薄膜:thin film
63. 薄膜混合电路:thin film hybrid circuit
64. 互连:interconnection
65. 导线:conductor trace line
66. 齐平导线:flush conductor
67. 传输线:transmission line
68. 跨交:crossover
69. 板边插头:edge-board contact
70. 增强板:stiffener
71. 基底:substrate
72. 基板面:real estate
73. 导线面:conductor side
74. 组件面:component side
75. 焊接面:solder side
76. 印制:printing
77. 网格:grid
78. 图形:pattern
79. 导电图形:conductive pattern
80. 非导电图形:non-conductive pattern
81. 字符:legend
82. 标志:mark
以上即是PCB设计中专业英译术语之综合词汇,下期预告:PCB设计中专业英译术语之基材,更多更多行业信息可查阅快点学院订阅号:eqpcb_cp。
http://www.eqpcb.com/shop/r/gou/images/img_93.jpg
谢谢分享啊
