MSP430 Flash编程程序
2008年10月22日 21:55 发布者:MSP430
//flash.c文件
#define __FLASH__
#define __HW_v_2_1__
#include "flash.h"
* This section contains all FLASH memory relevant functions: *
* writeByte *
* writeWord *
* eraseFLASH *
* saveInfoFlash *
* changeInfo *
* updateInfo *
Function : flash_writeFLASH
Parameter : *dst : address within the FLASH page
value : BYTE that has to be written to FLASH
Date : 08.09.2001 / 17.11.2002 / 22.11.2002
Description : this function writes a byte to an address in FLASH memory
warning: in FLASH only zeros can be written. if a bit value needs to be set to
one from zero, the whole page has to be erased, thus setting all bits to one.
then the value can be written correctly. this function does not perform. the
necessary FLASH page erase.
void flash_writeByte(BYTE *dst, BYTE value)
FCTL2 = FWKEY | FSSEL0 | 20; //clock source is MCLK, divisor is 20
do
_NOP();
} while(FCTL3 & 0x0001); // wait for BUSY to reset
FCTL3 = FWKEY; // reset the LOCK bit to enable program/erase
FCTL1 = FWKEY | WRT; // set WRT for single acces
*dst = value; // do the write as a byte
return;
Function : flash_writeWord
Date : 22.11.2002
Description : this function writes a word to an address in FLASH memory
void flash_writeWord(WORD *dst, WORD value)
do
_NOP();
*dst = value; // do the write as a word
return;
Function : flash_eraseFLASH
Parameter : *seg : any address within the FLASH page that is to be erased
Date : 08.09.2001 / 19.11.2002
Description : this function erases a FLASH page
void flash_eraseFLASH(BYTE *seg)
do
_NOP();
FCTL1 = FWKEY | ERASE; // set single segment erase function
*seg = 0xFF; // do a dummy write to start erase
FCTL3 = FWKEY | LOCK; // lock the flash again
return;
Function : flash_saveInfoFlash
Parameter : *container : pointer to updated copy of data in RAM
*flashPageBase : pointer to start of destination flash segment
Date : 11.09.2002 / 26.11.2002
Description : saves info flash page 0 to RAM (!!! works only for INFO flash access !!!)
void flash_saveInfoFlash(BYTE *container, BYTE *flashPageBase)
BYTE i;
flashPageBase = (BYTE*)((WORD)(flashPageBase) & 0xFF80); // wrap around for flash page base address
for(i=0;i<128;i++)
container = *flashPage++;
Function : flash_changeInfo
*pointer : original pointer to variable that has to be updated
value : new value for variable
Description : chages a word in the info flash 0 data (in RAM)
void flash_changeInfo(BYTE* containerBase, BYTE *pointer, BYTE value)
// pointer points into flash page to variable that is supposed to be changed
// subtract flash page offset (0x1000) and add scratch pad offset
pointer = (BYTE*)(((WORD)(pointer) & 0x7F) + (WORD)(containerBase));
*pointer = value;
Function : flash_update
Description : erases the flash page and writes the values from the RAM save area to flash
(!!! works only in INFO flash !!!)
void flash_updateInfo(BYTE *container, BYTE *flashPageBase)
// assumes prior saving and changing of flash data
BYTE i;
_DINT();
flash_eraseFLASH(flashPageBase);
for(i=0;i<128;i++)
flash_writeByte(flashPageBase++,*(container++));
_EINT();
/*flash.h文件
: copyright (c) Jean Randhahn :
: Project : CANeye - Uni Rostock :
: Compiler : IAR workbench GUI 2.31E / target descriptor v1.26A/WIN :
: class : flash :
: File name : flash.h :
: Target hardware : MSP430F148/9 :
: File Editor : J. Randhahn :
: Created : 06.08.2002 :
: Description : :
: Modification history: :
#ifndef __FLASH_H__
#define __FLASH_H__
#ifdef __FLASH__
/*::::::::::::::::::::::::: START OF LOCAL PART ::::::::::::::::::::::::::::::::*/
/*----------------------- LOCAL INCLUDES ---------------------------------------*/
#include
#include "type.h"
/*----------------------- LOCAL DEFINITIONS ------------------------------------*/
/*----------------------- LOCAL FUNCTION DECLARATIONS --------------------------*/
void flash_eraseFLASH(BYTE *seg);
void flash_writeWord(WORD *dst, WORD value);
void flash_writeByte(BYTE *dst, BYTE value);
void flash_saveInfoFlash(BYTE *container, BYTE *flashPage);
void flash_changeInfo(BYTE* containerBase, BYTE *pointer, BYTE value);
void flash_updateInfo(BYTE *container, BYTE *flashPageBase);
/*----------------------- LOCAL CONSTANTS AND VARIABLES ------------------------*/
/*----------------------- PUBLIC VARIABLES WITH INITIALISATION -----------------*/
/*::::::::::::::::::::::::: END OF LOCAL PART ::::::::::::::::::::::::::::::::::*/
#else
/*----------------------- PUBLIC VARIBALES INITIALIZED LOCALLY -----------------*/
#endif
/*-------------------- PUBLIC DEFINITIONS --------------------------------------*/
/*-------------------- PUBLIC CONSTANTS AND VARIABLES --------------------------*/
/*-------------------- PUBLIC FUNCTION DECLARATIONS ----------------------------*/
extern void flash_eraseFLASH(BYTE *seg);
extern void flash_writeWord(WORD *dst, WORD value);
extern void flash_writeByte(BYTE *dst, BYTE value);
extern void flash_saveInfoFlash(BYTE *container, BYTE *flashPage);
extern void flash_changeInfo(BYTE* containerBase, BYTE *pointer, BYTE value);
extern void flash_updateInfo(BYTE *container, BYTE *flashPageBase);
#endif
//type.h文件
/* START type definitions for convinience with microcontrollers ****************************/
typedef unsigned char BYTE; /* 8 bits */
typedef unsigned short WORD; /* 16 bits */
typedef unsigned long LONGWORD; /* 32 bits */
/* for dividing a WORD into two BYTEs */
typedef union _WORD_BYTE
{ WORD w;
BYTE b[2];
} WORD_BYTE;
