【分享】飞凌S3C6410 NAND Flash驱动程序 WindowsCE版
2010年08月06日 13:03 发布者:死亡天使
这段时间一直在研究S3C6410 NAND驱动,把找到的一些源码发出来,希望对正在做这部分的朋友有所帮助。
由于内容比较长,受字数和篇幅限制,详细代码可以在附件中下载。
本文转引自 飞凌嵌入式 ARM11 OK6410讨论区 www.witech.com.cn
// Copyright (c) Microsoft Corporation. All rights reserved.
#include
#include
#include
// BSP Configuration Files
#include "bsp_cfg.h"
#include "bsp_base_reg_cfg.h"
// Base Definitions
#include "s3c6410_base_regs.h"
#include "s3c6410_nand.h"
#include "s3c6410_syscon.h"
//#include
#include "Cfnand.h"
//#include
//#define SYNC_OP
#define CHECK_SPAREECC (1)
#define NAND_DEBUG (0)
#define NAND_BASE (0xB0200000) // PA:0x70200000
#define SYSCON_BASE (0xB2A0F000) // PA:0x7E00F000
#ifdef SYNC_OP
CRITICAL_SECTION g_csNandFlash;
#endif
static volatile S3C6410_NAND_REG *g_pNFConReg = NULL;
static volatile S3C6410_SYSCON_REG *g_pSysConReg = NULL;
NANDDeviceInfo GetNandInfo(void) { return stDeviceInfo; }
static DWORD ReadFlashID(void)
BYTE Mfg, Dev;
int i;
NF_nFCE_L(); // Deselect the flash chip.
NF_CMD(CMD_READID); // Send flash ID read command.
NF_ADDR(0);
for (i=0; i<10; i++)
Mfg = NF_RDDATA_BYTE();
if (Mfg == 0xEC || Mfg == 0x98) break;
Dev = NF_RDDATA_BYTE();
NF_nFCE_H();
return ((DWORD)(Mfg<<8)+Dev);
PVOID FMD_Init(LPCTSTR lpActiveReg, PPCI_REG_INFO pRegIn, PPCI_REG_INFO pRegOut)
volatile DWORD nNandID;
UINT8 nMID, nDID;
UINT32 nCnt;
BOOL bNandExt = FALSE;
RETAILMSG(1, (TEXT(" ++FMD_Init() ****\r\n")));
if (pRegIn && pRegIn->MemBase.Num && pRegIn->MemBase.Reg)
g_pNFConReg = (S3C6410_NAND_REG *)(pRegIn->MemBase.Reg);
else
g_pNFConReg = (S3C6410_NAND_REG *)NAND_BASE;
g_pSysConReg = (S3C6410_SYSCON_REG *)SYSCON_BASE;
#ifdef SYNC_OP
InitializeCriticalSection(&g_csNandFlash);
EnterCriticalSection(&g_csNandFlash);
#endif
if (!bNandExt)
RETAILMSG(1, (TEXT(" FMD_Init() : Unknown ID = 0x%08x\n"), nNandID));
return NULL;
NUM_OF_BLOCKS = astNandSpec.nNumOfBlks;
PAGES_PER_BLOCK = astNandSpec.nPgsPerBlk;
SECTORS_PER_PAGE = astNandSpec.nSctsPerPg;
RETAILMSG(1, (TEXT(" --FMD_Init()\n")));
return((PVOID)g_pNFConReg);
BOOL FMD_ReadSector(SECTOR_ADDR startSectorAddr, LPBYTE pSectorBuff, PSectorInfo
pSectorInfoBuff, DWORD dwNumSectors)
BOOL bRet;
//RETAILMSG(1, (TEXT(" \n"), startSectorAddr));
#if (NAND_DEBUG)
RETAILMSG(1, (TEXT(" ++FMD_ReadSector(0x%08x) \n"), startSectorAddr));
#endif
#ifdef SYNC_OP
#endif
if ( IS_LB )
bRet = FMD_LB_ReadSector(startSectorAddr, pSectorBuff, pSectorInfoBuff,
dwNumSectors, USE_NFCE);
else
bRet = FMD_SB_ReadSector(startSectorAddr, pSectorBuff, pSectorInfoBuff,
#ifdef SYNC_OP
LeaveCriticalSection(&g_csNandFlash);
#endif
#if (NAND_DEBUG)
RETAILMSG(1, (TEXT(" --FMD_ReadSector()\n")));
#endif
return bRet;
BOOL FMD_EraseBlock(BLOCK_ID blockID)
BOOL bRet = TRUE;
#if (NAND_DEBUG)
RETAILMSG(1, (TEXT(" ++FMD_EraseBlock(0x%08x) \n"), blockID));
#endif
#ifdef SYNC_OP
#endif
if ( IS_LB )
bRet = FMD_LB_EraseBlock(blockID, USE_NFCE);
else
bRet = FMD_SB_EraseBlock(blockID, USE_NFCE);
#ifdef SYNC_OP
#endif
#if (NAND_DEBUG)
RETAILMSG(1, (TEXT(" --FMD_EraseBlock()\n")));
#endif
return bRet;
BOOL FMD_WriteSector(SECTOR_ADDR startSectorAddr, LPBYTE pSectorBuff, PSectorInfo
BOOL bRet = TRUE;
#if (NAND_DEBUG)
RETAILMSG(1, (TEXT(" ++FMD_WriteSector(0x%08x) \n"), startSectorAddr));
#endif
#ifdef SYNC_OP
#endif
if ( IS_LB )
bRet = FMD_LB_WriteSector(startSectorAddr, pSectorBuff, pSectorInfoBuff,
else
bRet = FMD_SB_WriteSector(startSectorAddr, pSectorBuff, pSectorInfoBuff,
#ifdef SYNC_OP
#endif
#if (NAND_DEBUG)
RETAILMSG(1, (TEXT(" --FMD_WriteSector()\n")));
#endif
return bRet;
VOID FMD_PowerUp(VOID)
#if (NAND_DEBUG)
RETAILMSG(1, (TEXT(" FMD_PowerUp() \n")));
#endif
// Set up initial flash controller configuration.
g_pNFConReg->NFCONF = (TACLS<<12) | (TWRPH0<<8) | (TWRPH1<<4);
g_pNFConReg->NFCONT = (0<<17)|(0<<16)|(0<<10)|(0<<9)|(0<<8)|(1<<7)|(1<<6)|(1<<5)|
(1<<4)|(0x3<<1)|(1<<0);
g_pNFConReg->NFSTAT = (1<<4);
VOID FMD_PowerDown(VOID)
kanbudong
