Panasonic HE-S Series Power Relays
2015年11月09日 15:55 发布者:eechina
Panasonic HE-S Series Power Relays is the industry's smallest and lowest operating power multi-contact high-capacity power relays. The HE-S Series features a high-capacity resistive switching load rating of 5A at 277VAC for 50,000 cycles. The relay also features a mirror contact structure (compliant with EN60947-4-1) which uses a 2 Form A coupled with a 1 Form B contact arrangement. The HE-S Series has a normally open contact gap of 3.2mm which makes this relay VDE0126 compliant for European photovoltaic standards and meets the 2.5kV surge breakdown voltage between contacts required to be compliant with the EN61810-1 Industry standard.Features
35A @ 277VAC (50,0000 Cyles N.O.)
30 x 36 x 40mm Case Size
1,880 mW Nominal Operating Power / 170mW Coil Holding Power
Large Contact Gap and Insulation Distance
Mirror Contact Mechanisms
Benefits
High-capacity and long electrical life
Takes Up Less Board Space
Low Power Operation
Compliant with VDE0126 and EN61810-1 Standards
1 Form B Contact Can Be Used to Monitor the Condition of N.O. Contacts for Weld Detection
Applications
Photovoltaic Power Generation Systems (Solar Inverter)
Power Supplies (UPS)
Inverters
Office Air Conditioners
Industrial Equipment
Market Sectors / Industries
Photovoltaic Power
Energy Management
Industrial Electronics
View Product List
