ON Semiconductor STK984-090A-E 3-Phase Brushless DC Motor Driver
2015年09月25日 14:03 发布者:eechina
ON Semiconductor STK984-090A-E 3-Phase Brushless DC Motor Driver is a BLDC Intelligent Power Module consisted of a pre-driver and power MOSFET. It has a built-in shunt resistor and thermistor. Various protective functions against over-temperature, over-current, over-voltage and low voltage are incorporated. The BLDC motor drive circuit can easily be designed with a reduced PCB area.Features
Built-in pre-driver IC
Various protections (Overcurrent Protection, Over Temperature Protection, Low Voltage Protection, Over Voltage Protection) are incorporated
On board terminals that output fault signal on board a reset terminal
Built-in shunt resistor
Dual-Stage Charge-pump for low voltage operation (Cranking)
AEC-Q100 qualified and PPAP capable
Applications
Automotive
Industrial
Functional Diagram
View Product Detail
