急!XP系统32位机和WIN7系统64位机上LP Wizard10.5 破解失败找不到 License文件
2015年04月10日 16:26 发布者:JennyskySharry
我下载了LP Wizard10.5,我在XP系统32位机和WIN7系统的64位机上均无法成功破解,出现下面找不到license文件的错误提示,试了多次都是这样,真的好着急,哪位高手能帮忙尽快给提供下XP系统32位机和WIN7系统的64位机成功破解的有效方法,感激不尽!:)点击"Details"按钮出现的内容:The following FLEXlm errors were found: ServerF:\LP Wizard\LP Wizard 10.5 Crack\license.txt: Invalid (inconsistent) licensekey. The licensekey and data for the feature do not match. This usuallyhappens when a license file has been altered.Feature: lpeallegroLicense path: F:\LP Wizard\LP Wizard 10.5 Crack\license.txt;FLEXnet Licensing error:-8,523For further information, refer to the FLEXnetLicensing documentation,available at "www.flexerasoftware.com". ServerF:\LP Wizard\LP Wizard 10.5 Crack\license.txt: Invalid (inconsistent) licensekey. The licensekey and data for the feature do not match. This usuallyhappens when a license file has been altered.Feature: lpeallegroLicense path: F:\LP Wizard\LP Wizard 10.5 Crack\license.txt;FLEXnet Licensing error:-8,523For further information, refer to the FLEXnetLicensing documentation,available at "www.flexerasoftware.com". ServerF:\LP Wizard\LP Wizard 10.5 Crack\LP Wizard 10.5破解文件\license.txt: Cannot findlicense file. The licensefiles (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contactyour software provider for a license file.Feature: lpeallegroFilename: C:\flexlm\license.datLicense path: C:\flexlm\license.dat;FLEXnet Licensing error:-1,359. System Error: 2 "No such file ordirectory"For further information, refer to the FLEXnetLicensing documentation,available at "www.flexerasoftware.com". ServerC:\flexlm\license.dat: Cannot find license file. The licensefiles (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contactyour software provider for a license file.Feature: lpeallegroFilename: C:\flexlm\license.datLicense path: C:\flexlm\license.dat;FLEXnet Licensing error:-1,359. System Error: 2 "No such file ordirectory"For further information, refer to the FLEXnet Licensingdocumentation,available at "www.flexerasoftware.com".
jakeny1314 2017年03月12日
今天刚解决这个问题,64位 win 7 系统 ,安装后跟你的提示一模一样,不过,我考滤到有可能是license的路径有错误 ,所有重新弄了一下环境变量,然后重启一下电脑就OK了。
设置方法:我的电脑-右击属性-高级系统设置-高级-环境变量-在系统变量中添加:
变量名:MGLS_LICENSE_FILE
变量值为:D:\MentorGraphics\10.5LPW\SDD_HOME\LPWizard\license.txt
然后确定即可
然后确定即可
::o我也是这个情况啊,请高手解决。
