Vincotech Power Modules for Charger, Welding
2015年01月13日 15:28 发布者:eechina
These days power applications have to be able to operate at higher frequencies. The opportunity is that the transformer’svolume is inversely proportional to the switching frequency at every power level. As the switching frequency increases,
the volume decreases accordingly given the same power level. Switched Mode Power Supplies (SMPS) run at 50 kHz to
200 kHz, with lighter, smaller transformers. The system’s power dissipation – and especially that of the active electronic
components – has to be minimized. Otherwise the gain in power density and reduction in weight will come at the cost of
a bigger heatsink. The demand for grid-connected power electronics systems’ sinusoidal current sourcing, which requires
an active power factor correction (APFC) stage, is making this challenge even more daunting. After all, there is a tradeoff
between increased switching frequency and effi ciency. Although increasing the switching frequency helps reduce passive
components’ size and cost, it also takes additional eff ort to make effi ciency gains. Nonetheless, the circuit’s effi ciency and
cost can be optimized by selecting the right semiconductors and special topologies.
资料下载:143411
谢谢分享!!!!!!!!!!!!!
