关于FTP登录不上的问题
2009年07月22日 17:15 发布者:Anqi160
版主,自己您更换密码后,偶在下载东西时都是连接不上.现贴上Log,您给看一下啊FlashFXP v3.3.3 build 1100
心海e站: http://www.hrtsea.com
WinSock 2.0 -- OpenSSL 0.9.8 05 Jul 2005
[右] 正在连接到 202.165.177.77(www.eechina.com) -> IP=202.165.177.77 PORT=21
[右] 已连接到 202.165.177.77(www.eechina.com)
[右] 220 Serv-U FTP Server v6.3 for WinSock ready...
[右] USER embcom_ftp
[右] 331 User name okay, need password.
[右] PASS (隐藏)
[右] 230 User logged in, proceed.
[右] SYST
[右] 215 UNIX Type: L8
[右] FEAT
[右] 211-Extension supported
[右] CLNT
[右] MDTM
[右] MDTM YYYYMMDDHHMMSS[+-TZ];filename
[右] SIZE
[右] SITE PSWD;EXEC;SET;INDEX;ZONE;CHMOD;MSG
[右] REST STREAM
[右] XCRC filename;start;end
[右] MODE Z
[右] MLST Type*;Size*;Create;Modify*;Win32.ea*;
[右] 211 End
[右] CLNT FlashFXP 3.3.3.1100
[右] 200 Noted.
[右] PWD
[右] 257 "/" is current directory.
[右] TYPE A
[右] 200 Type set to A.
[右] MODE Z
[右] 200 MODE Z ok.
[右] PASV
[右] 227 Entering Passive Mode (202,165,177,77,17,5)
[右] 正在打开数据连接 IP: 202.165.177.77 端口: 4357
[右] LIST -al
[右] 150 Opening ASCII mode data connection for /bin/ls.
[右] 226 Transfer complete.
[右] 列表完成: 482 字节 于 0.61 秒 (0.8 KB/秒)
[右] CWD tyw
[右] 250 Directory changed to /tyw
[右] PWD
[右] 257 "/tyw" is current directory.
[右] PASV
[右] 227 Entering Passive Mode (202,165,177,77,17,6)
[右] 正在打开数据连接 IP: 202.165.177.77 端口: 4358
[右] LIST -al
[右] 列表完成: 2 KB 于 0.22 秒 (11.1 KB/秒)
[右] CWD 专辑类----EDA仿真相关专辑
[右] 250 Directory changed to /tyw/专辑类----EDA仿真相关专辑
[右] PWD
[右] 257 "/tyw/专辑类----EDA仿真相关专辑" is current directory.
[右] PASV
[右] 227 Entering Passive Mode (202,165,177,77,17,7)
[右] 正在打开数据连接 IP: 202.165.177.77 端口: 4359
[右] LIST -al
[右] 列表完成: 3 KB 于 0.23 秒 (13.1 KB/秒)
[右] QUIT
[右] 221 Goodbye!
[右] 已注销: 202.165.177.77(www.eechina.com)
[右] 正在连接到 202.165.177.77 -> IP=202.165.177.77 PORT=21
[右] USER embcom_ftp
[右] PASS (隐藏)
[右] 530 Not logged in.
[右] 连接失败
[右] 正在延迟 120 秒, 之后将尝试第 1 次重新连接
[右] 正在连接到 202.165.177.77 -> IP=202.165.177.77 PORT=21 (尝试 # 1)
[右] USER embcom_ftp
[右] PASS (隐藏)
[右] 连接失败
[右] 正在延迟 120 秒, 之后将尝试第 2 次重新连接
[右] 已放弃重新尝试
[右] USER embcom_ftp
[右] PASS (隐藏)
[右] 连接失败
fenghaili 2009年07月22日
居然真能转,不错……
居然真能转,不错……
tyw 2009年07月22日
搞勿懂老大为啥要换密码?流量太大干脆就暂停,跟密码有何相干?
riverpeak 2009年07月22日
老T叔勿生气哈哈,我也下载不了,用最新的密码也不行,估计就是有最大用户吧,大家都看您的好东西眼馋啊……
admin 2009年07月22日
回复1楼Anqi160:
1. 取消FTP的“PASV Mode”试试。
2. 每个ip仅限一个登录。
请楼主试试,不行的话我再想想别的办法。
回复1楼Anqi160:
2. 每个ip仅限一个登录。
请楼主试试,不行的话我再想想别的办法。
admin 2009年07月22日
tyw 发表于 2009-7-22 19:27 http://bbs.eechina.com/images/common/back.gif
回复老T叔,经常更换密码是为了防止非公社人员占用带宽,那样分配给公社人员的带宽就少了。
老郭 2009年07月22日
问题解决了吗?
问题解决了吗?
[右] PASV
[右] 227 Entering Passive Mode (202,165,177,77,11,94)
[右] 正在打开数据连接 IP: 202.165.177.77 端口: 2910
[右] MLSD
[右] 150 Opening BINARY mode data connection for MLSD.
[右] 列表完成: 405 字节 于 0.24 秒 (1.7 KB/秒)
[右] CWD fenghaili
[右] 250 Directory changed to /fenghaili
[右] PWD
[右] 257 "/fenghaili" is current directory.
[右] PASV
[右] 227 Entering Passive Mode (202,165,177,77,11,95)
[右] 正在打开数据连接 IP: 202.165.177.77 端口: 2911
[右] MLSD
[右] 列表完成: 1 KB 于 2.64 秒 (0.5 KB/秒)
错误: 站点管理器中没有“202.165.177.77”
[右] QUIT
[右] 221 Goodbye!
[右] 无法解析主机:40015.9505215509202.165.177.77
我可以登录,但是一下载就断了,咋回事
[右] PASV
[右] MLSD
[右] CWD fenghaili
[右] PWD
[右] PASV
[右] MLSD
[右] QUIT
[右] 221 Goodbye!
我可以登录,但是一下载就断了,咋回事
Anqi160 2009年07月23日
跟riverpeak的情况一样.能上去,但一下载就断掉啦
admin 2009年07月23日
回复riverpeak和楼上的:
[右] PASV
上面是riverpeak的ftp连接信息,好像并没有取消被动模式(PASV Mode),请在站点属性中修改后再重新尝试,附图如下:
1624
另外,会不会和个人防火墙有关系。我这边怎么连接都没有问题的:(
回复riverpeak和楼上的:
[右] PASV
1624
riverpeak 2009年07月23日
点了这个"使用被动模式"了,可以啦,奇怪了,以前怎么就没事?
admin 2009年07月24日
如果不取消“被动模式”,有的时候可能会连接上,但是不稳定的。
sunlichao 2014年08月03日
138192
按照这样的设置就可以了
138192
按照这样的设置就可以了
开始的时候我也没弄明白,后来多看了一些帖子就弄明白了
很好用的
很好用的
asbeforeEEChina 2014年08月31日
看来主动模式是可以的
看来主动模式是可以的
晕,请斑竹转到站务发帖
