S5PV210之Nand flash驱动编写
2014年12月10日 17:25 发布者:Embedsky007
大家好,又到了天嵌【嵌入式分享】的时间,相对于前几期【嵌入式分享】做的主要是TQ335X开发板的技术分享,本期决定做同是cortex-a8系列的TQ210开发板的技术分享。本期是关于TQ210开发板的Nand flash驱动编写,可能源码部分会比较多,本文由博主girlkoo编写,感谢他的分享。 跟裸机程序一样,S5PV210(TQ210)的Nand flash模块跟S3C2440(TQ2440)的Nand flash模块非常相似,如果不引入ECC,驱动程序的编写也非常简单,我是使用的Linux-3.8.6(Linux-3.8.3也一样)内核,驱动的API函数有些变化,不过原理是相通的,稍微看一下内核源码并参考下其他平台的相关代码就可以自己写出Nand flash驱动了,下面是Nand flash驱动的源码,没有启用ECC,当然,你也可以改成软件ECC,但是我的觉得既然软件ECC不如HWECC快,我就采用硬件ECC吧。[*]#include
[*]#include
[*]#include
[*]#include
[*]#include
[*]#include
[*]#include
[*]#include
[*]struct s5p_nand_regs{
[*] unsigned long nfconf;
[*] unsigned long nfcont;
[*] unsigned long nfcmmd;
[*] unsigned long nfaddr;
[*] unsigned long nfdata;
[*] unsigned long nfmeccd0;
[*] unsigned long nfmeccd1;
[*] unsigned long nfseccd;
[*] unsigned long nfsblk;
[*] unsigned long nfeblk;
[*] unsigned long nfstat;
[*] unsigned long nfeccerr0;
[*] unsigned long nfeccerr1;
[*] unsigned long nfmecc0;
[*] unsigned long nfmecc1;
[*] unsigned long nfsecc;
[*] unsigned long nfmlcbitpt;
[*]struct s5p_nand_ecc{
[*] unsigned long nfeccconf;
[*] unsigned long nfecccont;
[*] unsigned long nfeccstat;
[*] unsigned long nfeccsecstat;
[*] unsigned long nfeccprgecc0;
[*] unsigned long nfeccprgecc1;
[*] unsigned long nfeccprgecc2;
[*] unsigned long nfeccprgecc3;
[*] unsigned long nfeccprgecc4;
[*] unsigned long nfeccprgecc5;
[*] unsigned long nfeccprgecc6;
[*] unsigned long nfeccerl0;
[*] unsigned long nfeccerl1;
[*] unsigned long nfeccerl2;
[*] unsigned long nfeccerl3;
[*] unsigned long nfeccerl4;
[*] unsigned long nfeccerl5;
[*] unsigned long nfeccerl6;
[*] unsigned long nfeccerl7;
[*] unsigned long nfeccerp0;
[*] unsigned long nfeccerp1;
[*] unsigned long nfeccerp2;
[*] unsigned long nfeccerp3;
[*] unsigned long nfeccconecc0;
[*] unsigned long nfeccconecc1;
[*] unsigned long nfeccconecc2;
[*] unsigned long nfeccconecc3;
[*] unsigned long nfeccconecc4;
[*] unsigned long nfeccconecc5;
[*] unsigned long nfeccconecc6;
[*]static struct nand_chip *nand_chip;
[*]static struct mtd_info *s5p_mtd_info;
[*]static struct s5p_nand_regs *s5p_nand_regs;
[*]static struct s5p_nand_ecc *s5p_nand_ecc;
[*]static struct clk *s5p_nand_clk;
[*]static struct mtd_partition s5p_nand_partions[] = {
[*] .name = "bootloader",
[*] .offset = 0,
[*] .size = SZ_1M,
[*] .name = "kernel",
[*] .offset = MTDPART_OFS_APPEND,
[*] .size = 5*SZ_1M,
[*] .name = "rootfs",
[*] .size = MTDPART_SIZ_FULL,
[*]static void s5p_nand_select_chip(struct mtd_info *mtd, int chipnr){
[*] if(chipnr == -1){
[*] s5p_nand_regs->nfcont |= (1<<1);
[*] else{
[*] s5p_nand_regs->nfcont &= ~(1<<1);
[*]static void s5p_nand_cmd_ctrl(struct mtd_info *mtd, int cmd, unsigned int ctrl)
[*] if (ctrl & NAND_CLE){
[*] s5p_nand_regs->nfcmmd = cmd;
[*] else{
[*] s5p_nand_regs->nfaddr = cmd;
[*]static int s5p_nand_ready(struct mtd_info *mtd){
[*] return (s5p_nand_regs->nfstat & 0x1);
[*]static int s5p_nand_probe(struct platform_device *pdev){
[*] int ret = 0;
[*] struct resource *mem;
[*] //硬件部分初始化
[*] mem = platform_get_resource(pdev, IORESOURCE_MEM, 0);
[*] if (!mem) {
[*] dev_err(&pdev->dev, "can't get I/O resource mem\n");
[*] return -ENXIO;
[*] s5p_nand_regs = (struct s5p_nand_regs *)ioremap(mem->start, resource_size(mem));
[*] if (s5p_nand_regs == NULL) {
[*] dev_err(&pdev->dev, "ioremap failed\n");
[*] ret = -EIO;
[*] goto err_exit;
[*] s5p_nand_ecc = (struct s5p_nand_ecc *)ioremap(0xB0E20000, sizeof(struct s5p_nand_ecc));
[*] if(s5p_nand_ecc == NULL){
[*] ret = -EIO;
[*] goto err_iounmap;
[*] s5p_nand_clk = clk_get(&pdev->dev, "nand");
[*] if(s5p_nand_clk == NULL){
[*] dev_dbg(&pdev->dev, "get clk failed\n");
[*] ret = -ENODEV;
[*] clk_enable(s5p_nand_clk);
[*] s5p_nand_regs->nfconf = (3<<12)|(5<<8)|(3<<4)|(1<<1);
[*] s5p_nand_regs->nfcont |= 3;
[*] //分配驱动相关结构体
[*] nand_chip = (struct nand_chip *)kzalloc(sizeof(struct nand_chip), GFP_KERNEL);
[*] if(nand_chip == NULL){
[*] dev_err(&pdev->dev, "failed to allocate nand_chip structure\n");
[*] ret = -ENOMEM;
[*] goto err_clk_put;
[*] s5p_mtd_info = (struct mtd_info *)kzalloc(sizeof(struct mtd_info), GFP_KERNEL);
[*] if(s5p_mtd_info == NULL){
[*] dev_err(&pdev->dev, "failed to allocate mtd_info structure\n");
[*] ret = -ENOMEM;
[*] goto err_free_chip;
[*] //设置驱动相关结构体
[*] nand_chip->select_chip = s5p_nand_select_chip;
[*] nand_chip->cmd_ctrl = s5p_nand_cmd_ctrl;
[*] nand_chip->IO_ADDR_R = &s5p_nand_regs->nfdata;
[*] nand_chip->IO_ADDR_W = &s5p_nand_regs->nfdata;
[*] nand_chip->dev_ready = s5p_nand_ready;
[*] nand_chip->ecc.mode = NAND_ECC_SOFT;
[*] s5p_mtd_info->priv = nand_chip;
[*] s5p_mtd_info->owner = THIS_MODULE;
[*] //扫描Nand flash 设备
[*] if(nand_scan(s5p_mtd_info, 1)){
[*] dev_dbg(&pdev->dev, "nand scan error\n");
[*] goto err_free_info;
[*] //添加分区信息
[*] ret = mtd_device_parse_register(s5p_mtd_info, NULL, NULL, s5p_nand_partions, ARRAY_SIZE(s5p_nand_partions));
[*] if(!ret)
[*] return 0;
[*]err_free_info:
[*] kfree(s5p_mtd_info);
[*]err_free_chip:
[*] kfree(nand_chip);
[*]err_clk_put:
[*] clk_disable(s5p_nand_clk);
[*] clk_put(s5p_nand_clk);
[*]err_iounmap:
[*] //if(s5p_nand_ecc == NULL)
[*] // iounmap(s5p_nand_ecc);
[*] if(s5p_nand_regs == NULL)
[*] iounmap(s5p_nand_regs);
[*]err_exit:
[*] return ret;
[*]static int s5p_nand_remove(struct platform_device *pdev){
[*] nand_release(s5p_mtd_info);
[*] return 0;
[*]static struct platform_driver s5p_nand_drv = {
[*] .driver = {
[*] .owner = THIS_MODULE,
[*] .name = "s5p-nand",
[*] .probe = s5p_nand_probe,
[*] .remove = s5p_nand_remove,
[*]module_platform_driver(s5p_nand_drv);
[*]MODULE_LICENSE("GPL");
上述源码为嵌入式爱好者分享,如有更新,请咨询相关客服与销售人员,以便更新与开发。 操作所使用的硬件: TQ210V6开发板
