有深圳的朋友找工作吗?sagem招聘
2009年07月14日 23:20 发布者:riverpeak
Firmware Engineer(Printer)Responsibilities:
In charge of establish he specification, etablish the detailed Firmware design, write the source code and pass the unit tests and qualification test accordingly to a plan that he will have to prepare under the direct supervision of the team leader
Activities
1. Define the design of the firmware module: to identify and propose solutions to prove its necessary design margin.
2. Perform the development (specifications, design, code writing) and the qualification of the firmware module.
3. Define and perform the unit tests the firmware module in the product.
4. Report to his/her superior about the progress of the work, on technical aspects and planning.
5. Suggest refinements for methods and tools.
6. Ensure that technical information is collected, organised, and analysed, propose new ideas, propose projects/products.
7. Identify innovations so that they may be protected and capitalized on by patents.
Knowledge and skills:
1. Knowledge about embeded firmware development over at least one famous chipset (Intel, Motorola,..)
2. Knowledge about most popular Fw language,at least C, C++ (best also should be assembler language) and environment development (Visual C++ for example)
3. Knowledge about emulator system for embeded system
4. Knowledge about at least one saverage system tool (able to regenerate old version of a firmware)
5. Mastery of technical English
Testing Engineer(CPE)
Responsibilities
1.
Be Responsible of the quality of the product
2.
Define the test scenarios
3.
Make test planning
4.
Define and setup the test environment
5.
Perform the validation of the product
6.
Make test reports
7.
Participate in product function improvements
Requirement
1.
2 years experience with Bachelor degree
2.
Good knowledge of communication technologies
3.
Excellent knowledge of TCP/IP and related protocols
4.
Excellent organization skills
5.
Good communications skills
6.
Good learning skills and autonomy
7.
Analysis skills and rigor are required.
8.
Willingness to work in team
Validation Engineer
Responsibilities and Activities
Write test plan
Write reports
Good knowledge of Wifi protocol/Radio protocol/Ethernet protocol
Good knowledge of GPRS application/HTTP application/Gateway application
Very good english (written and spoken)
SW Engineer(Printer)
Responsibilities
1. In charge of establish he specification, etablish the detailed Firmware design, write the source code and pass the unit tests and qualification test accordingly to a plan that he will have to prepare under the direct supervision of the team leader
2. Define the design of the firmware module: to identify and propose solutions to prove its necessary design margin.
3. Perform the development (specifications, design, code writing) and the qualification of the firmware module.
4. Define and perform the unit tests the firmware module in the product.
5. Report to his/her superior about the progress of the work, on technical aspects and planning.
6. Suggest refinements for methods and tools.
7. Ensure that technical information is collected, organised, and analysed, propose new ideas, propose projects/products.
8. Identify innovations so that they may be protected and capitalized on by patents.
Skills
1. Knowledge about embeded firmware development over at least one famous chipset (Connexant, Toshiba, Zoran ,..)
McuPlayer 2009年07月15日
没沙发,板凳也要
没沙发,板凳也要
我的一个朋友内部推荐的,有找工作的朋友可以给我发简历我好帮忙转发
