来个宏定义玩玩,呵呵~
2009年07月14日 16:38 发布者:一朝成名
从驱动接口宏定义抽出来第一个数据结构
// Driver functions:驱动函数
CYG_ADC_FUNCTIONS( lpc2xxx_adc_funs,
lpc2xxx_adc_enable,
lpc2xxx_adc_disable,
lpc2xxx_adc_set_rate );
//doc中的解释说明
The macro CYG_ADC_FUNCTIONS() instantiates a function table called example_adc_funs and populates it with the ADC driver functions
//宏定义原型
#define CYG_ADC_FUNCTIONS( __name, __enable, __disable, __set_rate ) \
cyg_adc_functions __name = \
.enable = __enable, \
.disable = __disable, \
.set_rate = __set_rate \
//adc函数定义原型,一个结构体包含了三个函数指针
struct cyg_adc_functions
void (*enable)( cyg_adc_channel *chan );
void (*disable)( cyg_adc_channel *chan );
void (*set_rate)( cyg_adc_channel *chan, cyg_uint32 rate );
宏展开的结果:定义了一个cyg_adc_funtions包含了函数指针的结构体
cyg_adc_functions lpc2xxx_adc_funs{
.enable = lpc2xxx_adc_enable,
.disable = lpc2xxx_adc_disable,
.set_rate = lpc2xxx_adc_set_rate
//ADC信息的私有数据
static lpc2xxx_adc_info lpc2xxx_adc_info0 =
.base = CYGARC_HAL_LPC2XXX_REG_AD_BASE,
.vector = CYGNUM_HAL_INTERRUPT_TIMER1,
.intprio = CYGNUM_DEVS_ADC_ARM_LPC24XX_INTPRIO,
.int_handle = 0,
#if CYGPKG_DEVS_ADC_ARM_LPC24XX_DEBUG_LEVEL > 0
.isr_cnt = 0,
#endif
.chan_mask = 0
//ADC驱动的总结构,包含了上述的两部分驱动函数和私有数据
CYG_ADC_DEVICE( lpc2xxx_adc_device, //名字
&lpc2xxx_adc_funs, //驱动函数
&lpc2xxx_adc_info0, //驱动信息私有数据
CYGNUM_DEVS_ADC_ARM_LPC24XX_DEFAULT_RATE); //默认采样率
宏定义
#define CYG_ADC_DEVICE(__name, __funs, __dev_priv, __rate ) \
cyg_adc_device __name = \
.funs = __funs, \
.dev_priv = __dev_priv, \
.config.rate = __rate, \
.init = false \
展开宏定义的结果
cyg_adc_device lpc2xxx_adc_device = \
.funs = lpc2xxx_adc_funs, , \
.dev_priv = lpc2xxx_adc_info0,
.config.rate =CYGNUM_DEVS_ADC_ARM_LPC24XX_DEFAULT_RATE,
.init = false
//ADC0~7驱动的注册
LPC2XXX_ADC_CHANNEL(0~7)
//原型
#define LPC2XXX_ADC_CHANNEL( __chan ) \
CYG_ADC_CHANNEL( lpc2xxx_adc_channel##__chan, \
__chan, \
CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL##__chan##_BUFSIZE, \
&lpc2xxx_adc_device ); \
DEVTAB_ENTRY( lpc2xxx_adc_channel##__chan##_device, \
CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL##__chan##_NAME, \
0, \
&cyg_io_adc_devio, \
lpc2xxx_adc_init, \
lpc2xxx_adc_lookup, \
&lpc2xxx_adc_channel##__chan );
(1)第一步展开,将"##__chan"和"##_chan##"替换为__chan的数值,假设为0
CYG_ADC_CHANNEL( lpc2xxx_adc_channel0, \
0, \
CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL0_BUFSIZE, \
DEVTAB_ENTRY( lpc2xxx_adc_channel0_device, \
CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL0_NAME, \
0, \
lpc2xxx_adc_init, \
&lpc2xxx_adc_channel0 );
//CYG_ADC_CHANNEL宏定义原型
#define CYG_ADC_CHANNEL( __name, __channel, __bufsize, __device )
static cyg_adc_sample_t __name##_buf;
cyg_adc_channel __name =
.channel = __channel, \
.buf = __name##_buf, \
.len = __bufsize, \
.put = 0, \
.get = 0, \
.device = __device, \
.init = false \
(2-1)CYG_ADC_CHANNLE再次展开后的结果:
static cyg_adc_sample_t lpc2xxx_adc_channel0_buf; \
cyg_adc_channel lpc2xxx_adc_channel0 = \
.channel = 0, \
.buf = lpc2xxx_adc_channel0_buf, \
.len = CYGDAT_DEVS_ADC_ARM_LPC24XX_CHANNEL0_BUFSIZE, \
.put = 0, \
.get = 0, \
.device = &lpc2xxx_adc_device, \
.init = false \
(2-2)DEVTAB_ENTRY宏定义的原型
#define DEVTAB_ENTRY(_l,_name,_dep_name,_handlers,_init,_lookup,_priv) \
CHAR_DEVTAB_ENTRY(_l,_name,_dep_name,_handlers,_init,_lookup,_priv)
#define CHAR_DEVTAB_ENTRY(_l,_name,_dep_name,_handlers,_init,_lookup,_priv)
cyg_devtab_entry_t _l CYG_HAL_TABLE_ENTRY(devtab) = {
_name,
_dep_name,
_handlers,
_init,
_lookup,
_priv,
CYG_DEVTAB_STATUS_CHAR
展开结果
0,
lpc2xxx_adc_init,
lpc2xxx_adc_lookup,
&lpc2xxx_adc_channel0,
CYG_HAL_TABLE_ENTRY()原型
#define CYG_HAL_TABLE_ENTRY( _name ) \
CYGBLD_ATTRIB_SECTION(".ecos.table." __xstring(_name) ".data")
CYGBLD_ATTRIB_USED
展开结果
CYGBLD_ATTRIB_SECTION(".ecos.table.devtab.data")
CYGBLD_ATTRIB_USED
CYGBLD_ATTRIB_SECTION原型
#define CYGBLD_ATTRIB_SECTION(__sect__) __attribute__((section (__sect__)))
展开结果
__attribute__((section (".ecos.table.devtab.data")))
展开CYGBLD_ATTRIB_USED
__attribute__((used))
CYG_HAL_TABLE_ENTRY()的展开结果为
DEVTAB_ENTRY的展开结果为
cyg_devtab_entry_t _l __attribute__((section (".ecos.table.devtab.data"))) __attribute__((used)) = {
0,
lpc2xxx_adc_init,
lpc2xxx_adc_lookup,
总结LPC2XXX_ADC_CHANNEL(0)的宏定义结果为
.channel = 0,
.put = 0,
.get = 0,
.init = false
0,
lpc2xxx_adc_init,
lpc2xxx_adc_lookup,
因为公社的版本太窄了,导致很多行都乱了,所以把一些还行符删掉了~
看人家老外做的程序,专业~看不懂~:lol
我要是分析的不对的,大家指正
一朝成名 2009年07月16日
果然是没人看:D
果然是没人看:D
masonz 2009年08月25日
看不懂,为何要加个点(.enable)
看不懂,为何要加个点(.enable)
自己沙发,消灭0回复:lol
