Board Viewer 2014下载
2014年05月07日 14:41 发布者:chenyuanzhi1989
Features of Board Viewer[*]PCB/Panel/Footprint data can be referred.
[*]Display on/off and color of each layer can be specified.
[*]The order of the display of each layer can be specified.
[*]Visible Layer Group can be configured.
[*]Display "Mirror View" is supported.
[*]The display color of each signal can be specified.
[*]Data can be searched by Signal name, Reference Designator and Terminal in PCB data.
[*]Detailed information on data can be referred.
[*]The distance between the data can be measured.
[*]Distance between two points can be measured using the Ruler tool.
[*]Add, delete or move the text comments in Board Viewer.
[*]One PCB data file can be referred to from multiple Board Viewers simultaneously.
System ConfigurationThe following configuration is required.
OS
[*]Windows 8.1 Enterprise (32bit/64bit)
[*]Windows 8.1 Pro (32bit/64bit)
[*]Windows 8.1 (32bit/64bit)
[*]Windows 7 Ultimate No SP/SP1(32bit/64bit)
[*]Windows 7 Enterprise No SP/SP1(32bit/64bit)
[*]Windows 7 Professional No SP/SP1(32bit/64bit)
[*]Windows 7 Home Premium No SP/SP1(32bit/64bit)
[*]Windows Vista Ultimate SP2 (32bit/64bit)
[*]Windows Vista Enterprise SP2 (32bit/64bit)
[*]Windows Vista Business SP2 (32bit/64bit)
CPU2GHz or faster
RAM1GB or higher
Virtual memorySystem recommended value
Hard disk39MB free space or more
Display1024 x 768 screen resolution or more,
16bit High Color / 32768 colors or more
Supported revision of board data
Board Designer
[*]Rev.16.xxx
[*]Rev.15.xxx
[*]Rev.14.xxx
[*]Rev.13.xxx
[*]Rev.12.xxx
[*]Rev.11.xxx
[*]Rev.10.xxx
[*]Rev.9.xxx
[*]Rev.8.xxx
[*]Rev.7.xxx
Design Force
[*]2014.xxx
[*]2013.xxx
[*]2012.xxx
DFM Center
[*]2014.xxx
[*]2013.xxx
[*]2012.xxx
[*]Rev.5.0
[*]Rev.4.0
DFM Elements
[*]2012.xxx
DFM Inkjet
[*]2014.xxx
[*]2013.xxx
[*]2012.xxx
[*]Rev.1.3
135197
spy007868 2014年05月08日
下载下来!!!!!!!!我自己好好学习!!!!!!!!!!!!!!!!!!
pcbkey 2015年01月31日
下载下来看一下
下载下来看一下
https://support.zuken.co.jp/global/downloads/Pub/bv?lang=eng
