a3p060 烧写问题
2009年06月25日 14:32 发布者:wangkj
我吧vjtag,vpump直接接到3.3V了。出现这个错误:
programmer 'FPBBALTLPT1' : Scan Chain FAILED.
是不是vjtag必须接上拉电阻?
vpump必须用电容?
如果需要,要多大的?
programmer 'FPBBALTLPT1' : Scan Chain...
Error: programmer 'FPBBALTLPT1' : Signal Integrity Failure
Integrity Check Pattern Not Found.
Integrity Check Pattern :
550FAAF000FF0000FFFF
IrScan Error.
TDO stuck at 0
Chain Analysis Failed.
Error: programmer 'FPBBALTLPT1' : Data Bit length : 8272
Error: programmer 'FPBBALTLPT1' : Compare Data :0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Error: programmer 'FPBBALTLPT1' : Scan Chain FAILED.
Error: Failed to run Action.
wangkj 2009年06月25日
网上找到的答案是vjtag 200欧电阻上拉,vpump加电容。
wangkj 2009年06月25日
1248780
这是原理图。
1248780
这是原理图。
wangkj 2009年06月27日
可能是vjtag的问题,飞线比较难办。
实验室的门开不开了,只好回家用自己的设备了。
以前是能开开的,唉,郁闷。
可能是vjtag的问题,飞线比较难办。
以前是能开开的,唉,郁闷。
wangkj 2009年06月27日
还得给自己的电脑安装软件。
还得给自己的电脑安装软件。
wangkj 2009年06月27日
另外的说法就是去掉r4,r5电阻。
另外的说法就是去掉r4,r5电阻。
wangkj 2009年06月29日
拆掉那两个电阻,vjtag 加200欧姆电阻,故障依旧。
看来得找个usb的编程器了。
俺自己想办法。不知道谁有卖的。
看来得找个usb的编程器了。
俺自己想办法。不知道谁有卖的。
wangkj 2009年07月01日
用usb的烧写器好了。
用usb的烧写器好了。
hushucon 2010年10月11日
回复1楼wangkj:
回复1楼wangkj:
问题解决了吗,我遇到了和你一样的问题,能知道下吗? 回复1楼wangkj:
貌似我找不到 fpga/cpld应该划分到那个类别,5个主题好像都不太合适。
